05 -07 Police ABS Recall
ORIGINAL: TN_Lowrider
Found this when I entered my vin a few minutes ago.
Recall Notice: 0134: 2005-07 POLICE ABS BRAKELINE
Just an FYI. Not sure if this is a repost or not. Didn't see much info of course. Guess I need to make a run to the stealership.
The ABS system itself is not defective......the recall was issued for inspection and replacement, if neccessary,of the brake lines from rubbing and chaffing and some new stand off clips and clocking devices to eliminate the possibility of a problem in the future. These would be the metal lines that run down the front frame down tube and rear mastercylinder along the bottom of the frame to the rear AND the rubber lines around the rear wheel and ABS controller.
Yep... Just found this.
Make : HARLEY DAVIDSON
Model : FLHP
Year : 2007
Manufacturer : HARLEY-DAVIDSON MOTOR COMPANY
Mfr's Report Date : FEB 25, 2008
NHTSA CAMPAIGN ID Number : 08V090000
N/A[/align]NHTSA Action Number: N/A
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK
Potential Number Of Units Affected : 5947
Summary:
HARLEY-DAVIDSON IS RECALLING 5,947 MY 2005-2007 FLHP, FLHPI, FLHTP, FLHTPI, FLHPE AND FLHPEI POLICE AND ESCORT MOTORCYCLES EQUIPPED WITH ANTI-LOCK BRAKE SYSTEMS (ABS). INCONSISTENCIES IN THE ROUTING OF THE BRAKE LINES CAN CAUSE ABRASION OF THE BRAKE LINES AND HOSES. IN SOME CASES, THIS CONDITION HAS CAUSED BRAKE FLUID LEAKS.
Consequence:
LOSS OF BRAKE FLUID COULD LEAD TO LOSS OF BRAKE FUNCTION, WHICH COULD LEAD TO A CRASH RESULTING IN INJURY OR DEATH.
Remedy:
DEALERS WILL INSPECT AND REPLACE THE BRAKE LINES, IF NECESSARY. BRAKE LINE RETENTION AND CLUTCH CABLE POSITIONING DEVICES WILL ALSO BE INSTALLED TO PREVENT FUTURE ABRASION TO THE BRAKE LINES. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT MARCH 10, 2008. OWNERS MAY CONTACT HARLEY-DAVIDSON AT 1-414-342-4680.
Notes:
HARLEY-DAVIDSON RECALL NO. 0134. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Model : FLHP
Year : 2007
Summary:
![](http://www-odi.nhtsa.dot.gov/images/spacer.gif)
Consequence:
Remedy:
Notes:
Buckinfitch
01-12-2012 02:40 PM
