ABS brake line
Old Oct 7, 2008 | 01:13 PM
wdcamp's Avatar
wdcamp
Default ABS brake line
Is there an extended ABS brake line available for the 08s? If not HD, which after market supplier? I am changing bars on my RK. Thanks alot.
Old Oct 7, 2008 | 01:43 PM
HarleyWood's Avatar
HarleyWood
Barnett gets recommended a lot.
http://www.barnettclutches.com/produ...ake_lines.aspx
I found a local supplier here in town that makes brake lines
Old Oct 7, 2008 | 02:44 PM
shooter64's Avatar
shooter64
Former Sponsor
I havent seen one....but I havent looked really, I will look for you, I did see somebody came out with a throttle by wire plug extension
Old Oct 7, 2008 | 02:51 PM
06WideGlide's Avatar
06WideGlide
Try
www.johnnyvaughn.com
As I understand it the brakes will need to be bleed by a dealer.
Old Oct 7, 2008 | 03:32 PM
badjustbad's Avatar
badjustbad
Originally Posted by 06WideGlide
Try
Johnny (HD Bike Parts) is where I bought my ABS brake cable, clutch cable, and wiring extensions, too.
BTW, you don't need to have the brakes bled by the dealer. In fact, I read that statement in the service manual, too, so I went to my local dealer and asked them. They knew nothing about it. I was just careful to bleed them thoroughly and everything was fine.
Old Oct 7, 2008 | 11:48 PM
06WideGlide
Check out this thread on bleeding ABS brakes
https://www.hdforums.com/forum/touring-models/283641-bleeding-the-brembos-with-abs.html
caulk04
Sep 17, 2018 04:36 PM
Woodys03
Wheels/Tires
Sep 4, 2015 02:10 AM
powerstroke8oh8
May 1, 2010 01:34 AM
JonnyD
Jul 24, 2008 12:03 AM
carberryt
Jan 13, 2008 03:01 AM
