Brake line, same reach ABS vs non-ABS?
Old Sep 17, 2018 | 07:49 AM
caulk04's Avatar
caulk04
Default Brake line, same reach ABS vs non-ABS?
Just picked up a 2011 Street Glide with ABS and I'm just checking boxes before I swap bars. My last bike was an 08 non-ABS and the stock brake line reached the 10" bars I installed just fine. Will the ABS line reach just the same or are they shorter?
Old Sep 17, 2018 | 07:54 AM
bigpappa160's Avatar
bigpappa160
You should be alright with the brake line length! When you take front fairing off just measure from the fitting where the lines go into up to the length of the bars. I don't think Harley shorten brake lines just because the bike has abs or not!
Old Sep 17, 2018 | 01:08 PM
jory434's Avatar
jory434
The brake line on a ABS bike actually leaves the bars and goes to the ABS module under the side cover (under the seat). You should be ok with 10" bars using the same line. I only had to snip a zip tie up by the steering neck on the right side to give my brake line a little more room to reach.
Old Sep 17, 2018 | 04:36 PM
caulk04's Avatar
caulk04
Thanks guys, I figured I was fine but over time I've learned to assume less...
Jeepin79
Nov 21, 2014 11:12 AM
semifan1
Mar 7, 2014 11:23 PM
Youngneg
Jan 23, 2012 10:13 AM
powerstroke8oh8
May 1, 2010 01:34 AM
wdcamp
Oct 7, 2008 11:48 PM
