Brake Line Question
Old Nov 20, 2014 | 11:36 AM
Jeepin79's Avatar
Jeepin79
Default Brake Line Question
Does anyone know if there is a difference in ABS lines and non-ABS lines? I am swapping the bars off my bike back to a stock set and will ultimately sell the bars I have. I bought a set of stock bars/line/etc and the ones I bought came off of an ABS bike. Just want to make sure there is not any difference before I put the ABS lines on my bike to trade it in.
Old Nov 20, 2014 | 11:53 AM
hoethree's Avatar
hoethree
Would like to know also
Old Nov 20, 2014 | 12:29 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The lines themselves are the same. ABS bikes have more lines as there is a line that goes from the master cylinder to the ABS box, and then a line from the abs box up to the front calipers. They all hold DOT 4 brake fluid on 2008 and newer touring bikes.
Old Nov 20, 2014 | 12:38 PM
Jeepin79's Avatar
Jeepin79
I will have to look at the lines and see if they lengths will work for my non ABS bike. I did not even pay attention to what was exactly there.
Old Nov 20, 2014 | 12:49 PM
leon anthony's Avatar
leon anthony
I have a 1979 CJ5
Hogpro's Avatar
Hogpro
Former Sponsor
I would imagine off an ABS bike that the lines will be far too long for a non ABS bike if they are stock and all one piece as they are designed to go back to under the right side cover from the front.
Old Nov 20, 2014 | 02:17 PM
Joe12RK's Avatar
Joe12RK
They are way different!
Non ABS:
http://www.granitestateharleystore.c...~NON-ABS%5CFBM
ABS:
http://www.granitestateharleystore.c...S%7C~ABS%5CFBM
Old Nov 20, 2014 | 05:28 PM
14GuineaPig's Avatar
14GuineaPig
The brake line for abs goes from the master to the ABS module.
The line for Non-ABS goes from the master cylinder directly to the calipers.
http://www.granitestateharleystore.c...ES%7C~ABS%5CKB
http://www.granitestateharleystore.c...C~NON-ABS%5CKB
Old Nov 20, 2014 | 05:32 PM
14GuineaPig
Guess I should read every post before I reply. Sorry Joe, I never scrolled down far enough to read your post.
Old Nov 20, 2014 | 05:54 PM
SBates08's Avatar
SBates08
If the length is ok for what your trying to accomplish, use it. There is no difference in the line itself. But unless your tying into a distribution block above the fender I doubt you'll make it work.
2010 Limited with some stuff!!
