Service manual-Primary Lube ?
Old 04-22-2008, 09:11 AM
Akitakoi's Avatar
Akitakoi
Akitakoi is offline
Default RE: Service manual-Primary Lube ?
ORIGINAL: SG 1
I think 38oz. is capacity. I don't think you can get all 38 oz. out just draining. If you had to remove the primary cover for any reason then you would need the full 38 oz.
BINGO!
Takes about 32 oz when you change it.
Old 04-22-2008, 09:23 AM
devobail's Avatar
devobail
devobail is offline
ORIGINAL: Akitakoi
ORIGINAL: SG 1
BINGO!
Not true, the manual states to add 45 oz. any time you remove the primary cover, add 38 if its only a change. I change my oil just yesterday and it took 38 oz just fine. Matter of fact i did it twice yesterday. Dont ask me why. (Beer is wonderful) lol
Old 04-22-2008, 06:36 PM
jack49's Avatar
jack49
jack49 is offline
0688"owners manual says drain and fill with 32oz. primary oil, and
warns against overfilling. Why is there a debate over this,didn't
anyone get a simple owners manual with their 20K bike?
Could be the 96" primary holds more oil then the 88", not owning one,
I wouldn't know.
Old 04-22-2008, 07:38 PM
cardboard's Avatar
cardboard
cardboard is offline
All you got to do is look at the measurements on the side of the bottle. Put 1 quart in with a funnel and put 6 oz out of another bottle. Look at the bottom of the primary there is a circle cut out so the oil can go in easier.
I don't understand if the manual says to put 38 oz in that you would want to put less in. The level comes up to about the bottom of the clutch pack. The primary oil lubricated the primary chain, the tensioner, the clutch pack and sprockets etc.
Put the bike on a jack and make it level but so you can git the drain plug out. Take the derby cover off and look inside at the oil level.
Old 04-22-2008, 07:46 PM
Skivvy9r's Avatar
Skivvy9r
Skivvy9r is offline
My '08 took 38 oz. Put in 32 oz first and checked. It was too low so, I added the 6 additional ounces and the level was right where it was before the change.
Old 04-22-2008, 07:54 PM
Oldman Harley's Avatar
Oldman Harley
Oldman Harley is offline
Just did this on Sunday. It took 38oz just like the manual says. 45oz for a dry fill---ie--if you take the primary cover off and remove the clutch.
Tim
Old 04-22-2008, 08:53 PM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
One thing I would add to this is not to do it in the order that the manual says. First remove the derby cover, THEN the drain plug. That ensures that you don't drain the primary and then have trouble getting the derby cover off. This results in a primary with no oil and no way to easily fill it back up. Ask me how I know this??? :-)
JakeUSAF
2014-2023 Touring Models
11-02-2015 08:03 PM
Rick341
06-18-2012 01:29 PM
scottharstad
05-14-2009 12:10 AM
urdollar
01-19-2008 01:56 PM
Ultrasweet
06-10-2007 09:30 AM
Quick Reply: Service manual-Primary Lube ?
