calling everyone with a stereo!!
Old 05-01-2008, 05:50 PM
Ganzo68's Avatar
Ganzo68
Ganzo68 is offline
Default calling everyone with a stereo!!
I want to know who has installed an aftermarket amp and speakers on their sg and what amp have you used. I am interested in hog tunes but if there is something comparable for less money that I can wire in myself I am all for it. I can't stand not hearing my tunes! Thanks
Old 05-01-2008, 06:01 PM
drrandall1's Avatar
drrandall1
drrandall1 is offline
Default RE: calling everyone with a stereo!!
You know I was happy with my stereo at first. But when you are at 70+mph it gets pretty quiet and starts to get distorted when you crank. Wonder how much it is to get the amp and speakers at the dealer installed?
Old 05-01-2008, 06:44 PM
spence222's Avatar
spence222
spence222 is offline
I just received my Pyle 240 watt amp...$55 on ebay(new)....going to install it this weekend to a Sony from biketronics....from what I've heard it a simple install.....I'll check back and let you know how it sounds....
Old 05-01-2008, 06:50 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
AK_Hog_Herder is offline
06 Ultra with the stock HK radio and 4 HogTunes speakers (thanks Pez !!).
Amp ?? We don't need no steekin' amp!!
Old 05-01-2008, 07:26 PM
rickxx's Avatar
rickxx
rickxx is offline
i added the hogtunes amp and speakers to the sg. easy....except for running the power wire under the tank. sounds great too.
Old 05-01-2008, 07:32 PM
dowork08's Avatar
dowork08
dowork08 is offline
did the hog tunes amp bost up your volume at high speeds..
Old 05-01-2008, 07:33 PM
HDMomma's Avatar
HDMomma
HDMomma is offline
You don't need to pay the dealer to install the speakers. My husband and I did both of our SG's in less than 30 minutes. Really easy and truly plug and play. And we had never taken our fairings apart either. As for the amp, I haven't done that. I can tell you that just replacing the two speakers with the Hog Tunes on our bikes it made a world of difference. No distortion when you crank it. Next I want to install tweeters.
Old 05-01-2008, 07:58 PM
drrandall1's Avatar
drrandall1
Normally distortion means the speakers need more power from the stereo. So if I installed better speakers I would think the sound would be worse without an amp.
Old 05-01-2008, 08:07 PM
Sodiee's Avatar
Sodiee
Sodiee is offline
I started out with JBLs.They were better than stock but not good enough.I saved my money and went with the Hawg Wired amp and speakers.Now I have a great sounding system,even at high speeds,and I have no regreats.If moneys not too tight,I would recommended this set-up.
Old 05-01-2008, 08:12 PM
mikes300's Avatar
mikes300
mikes300 is offline
yep same here hawg wired amp and component speakers, expensive but awesome sound.
Mike
Quick Reply: calling everyone with a stereo!!
