Engine light coming on 2000 FLHRCI
Old May 9, 2008 | 06:22 PM
dslwraith's Avatar
dslwraith
Default Engine light coming on 2000 FLHRCI
What would cause the engine light to come on and then go off??
The bike was just serviced for its 20k mile service at the dealership.
Everyhting runs fine, just wondering what reasons it comes on.
Thanks in advance
Brandon
Old May 9, 2008 | 06:52 PM
hogbag07's Avatar
hogbag07
Default RE: Engine light coming on 2000 FLHRCI
Falt detected check trouble codes
Old May 9, 2008 | 07:01 PM
dslwraith's Avatar
dslwraith
So what do they charge to check codes at the dealership?
Old May 9, 2008 | 07:20 PM
hogbag07's Avatar
hogbag07
Use the serch engine on this page.Type in delphi codes or try delphi ecm codes or falt codes for delphi .Its not hard to check yourself the dealer might charge $. I can't help you my bikes a 2007
Old May 9, 2008 | 07:23 PM
RKC2001's Avatar
RKC2001
2000 FLHRCIs have the Magnetti Morelli ECM so if you're going to search use that.
Old May 9, 2008 | 07:35 PM
dslwraith's Avatar
dslwraith
Searched cant find anything on the codes unless i missed something in the search.
Just wondering it runs fine it just comes on for a second then goes off.
Coudl it possibly read a false code if you just do something wrong, shift down when you meant to go up and cause the rpms to drop quickly etc etc
Or someother stupid mistake liek that
Still getting used to the bike , my previous bike was a 650, this bad boy has the 95" kit on it so it has a little more power to handle....
Old May 9, 2008 | 08:05 PM
glide's Avatar
glide
1. Remove right side saddlebag and side cover. Remove protective plug from data link connector.
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A “trip†consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)
10 24 Loss of vehicle speed
10 33 Loss of vehicle inhibit motion
10 43 Loss of power train security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cyl
Old May 9, 2008 | 10:07 PM
dslwraith's Avatar
dslwraith
anyone have any help on doing this yourself? what exactly do i need???
Conga
Apr 7, 2018 11:49 AM
Kyle C Kirk
Nov 9, 2015 02:13 PM
luckydawg110609
Mar 14, 2011 01:35 PM
gt46660
Sep 2, 2009 09:53 PM
mastermechanic
Jul 8, 2007 10:14 PM
