Speakers
Old Jun 2, 2008 | 12:55 PM
98UltraEvo's Avatar
98UltraEvo
Default Speakers
My 98 Ultra left rear speaker has stopped working, looks like all the connects are good, is there a way to test the speaker and to see if the signal is coming from the radio?
Thanks,[8D]
Old Jun 2, 2008 | 12:58 PM
Lt James's Avatar
Lt James
Default RE: Speakers
Connecting a battery across the terminals is a crude test that should give you a "hum" if the speaker still works. Don't hold it on there though. I've used 9V battereies for my 5.1 system in my house when troubleshooting with no ill-effects.
Old Jun 2, 2008 | 01:11 PM
Puggy's Avatar
Puggy
You can either put a meter across the leads to see if there's voltage or just pull the other speaker and plug the one in question to that side to see if it works.
Old Jun 2, 2008 | 01:59 PM
heavymetalthunder's Avatar
heavymetalthunder
Best way to test is with a digital Volt/Ohm meter. Unhook the leads from the speaker and ohm out the speaker. It will read lower than what its rated and it will show OL if its open. If it ohms out ok set the meter to AC volts and hookup to the speaker leads. Turn the radio on and watch the meter it should show the voltage going up and down at no set voltage. Varying with the music. If theres no ac voltage coming out of the wires switch the meter to dc. If theres dc voltage there. You have radio problems on that channel.
Old Jun 2, 2008 | 02:21 PM
Slope's Avatar
Slope
Sorry, I don't mean to insult your intelligence, put did you check the obvious (balance setting)? Sometimes we get so into fixing something that we miss the simple things.
Old Jun 2, 2008 | 02:54 PM
chiabate's Avatar
chiabate
That could happen to any of us. Been there, done that!
Old Jun 2, 2008 | 04:08 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
I'm kind of lazy.
I would pull the other speaker and hook it up. If you got music, your original speaker is duff. If you ain't, you either have a wire or output issue from the radio.
Mikerunsjax
Audio Systems
Feb 25, 2018 10:10 AM
clackavosticus
Audio Systems
Aug 4, 2017 07:36 AM
InthewindMN
Audio Systems
Aug 14, 2016 08:38 PM
Iron 1250
Audio Systems
Jun 2, 2016 09:38 PM
STREAK
Audio Systems
11
Mar 8, 2014 12:00 AM
