Wind Deflectors Hit Engine Guard
Old 07-18-2008, 07:56 PM
hitone's Avatar
hitone
hitone is offline
Default Wind Deflectors Hit Engine Guard
I&nbsp\\;put a set of the Kuryakyn chrome fork mounted wind deflectors on my 2007 Street Glide today. They fit perfectly despite the many comments I have had that they won't fit because the FLHX has the turn signals mounted on the forks. Just ondo the 2 #40 torx bolts on each fork&nbsp\\;and slip them on.
The problem is the engine guard on a stock FLHX. I had to remove it because the deflectors hit the guard and prevent turning the wheel from lock to lock. Now I need to find someone who has replaced the engine guard or altered it somehow so I have some peace of mind in the event the bike falls over or goes down at a slow speed.
I looked on the websites but noone gives the dimensions of their products so I can measure to see if I get clearance.
Anyone out there got a solution. Thanks in advance!
Old 07-18-2008, 08:20 PM
Medicfrost's Avatar
Medicfrost
Medicfrost is offline
Default RE: Wind Deflectors Hit Engine Guard
Replace the engine guards with moustache guards
Old 07-18-2008, 09:20 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Then I would say that they don't fit perfectly after all.
Old 07-18-2008, 11:12 PM
skratch's Avatar
skratch
skratch is offline
Received 4,246 Likes on 2,476 Posts
i agree with jim if it were me i'd rather have the engine guard than the wind deflectors anyway
Old 07-18-2008, 11:53 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
Engine Guards did nothing on my RKC but the Engine Guard protects your LEGS in case it goes over and other hard parts.
Old 07-19-2008, 12:08 AM
flyingace's Avatar
flyingace
flyingace is offline
And now you know why they say they DONT fit.
Old 07-19-2008, 06:33 AM
kurtlange's Avatar
kurtlange
kurtlange is offline
swap the wind deflectors&nbsp\\;side for side.
Old 07-19-2008, 08:01 AM
jag1886's Avatar
jag1886
jag1886 is offline
&nbsp\\;The factory Harley ones do the same thing.&nbsp\\;I took them back off.
Old 07-19-2008, 08:59 AM
CGLTD's Avatar
CGLTD
CGLTD is offline
The same thing happened with my hd ones and I switched sides. I bought them used and didn't have instructions so I figured I put them on backwords the first time. Anyway they work great when I switched them around.
Old 07-19-2008, 01:05 PM
StrongIslander's Avatar
StrongIslander
StrongIslander is offline
Be thankful ya didn't have the HD instructions, as usual they made my install more confusing.&nbsp\\; Finally put 'em down, took a good look at the pieces and&nbsp\\;put them right on...what was I thinking...
Quick Reply: Wind Deflectors Hit Engine Guard
