Turn signals for touring pack ?
I just installed the Complete Turn Signal LED Conversion Kits with the Street Magic Signal Stabilizer and the Street Magic Triple Play Run/Brake/Turn Controller to add running and brake functionality. Now going with the LEDs for the touring pack. Is there any way to make the touring pack lights turn signals with the set up I have.
Thanks
Thanks
Ridetime Technology has what you want. They are $100 but you can wire them any way you want and they are brighter. I don't have the tour pak lights yet but I will be installing them over the winter. I have some of his other lights and they are bright. It's pretty easy to get Keith on the phone too and he will answer any questions that you have.
The TP wiring harness is not seperated by right/left sides, and has run/brake/ground wires. It should be a relatively easy to split the TP's wiring (inside the TP) to create left and right side circuits, and connect those circuits to an HD run/brake/turn signal module by splicing to the module under the seat. I did this with my saddlebag LED/spoilers to add the turn signal function. This was pretty simple since the LED's for each spoiler exits the its saddlebag with a seperate harness. Since the lights in the TP are on a common circuit exiting the TP, the circuits (left/right) would need to be seperated.
If you want a removeable TP, it would be necessary to add a quick disconnect between the TP and bike wiring.
For those using aftermarket solutions like RideTime's, how is the install accomplished?
