Broken Brackets
Interesting thread - I've never heard of this problem before but I'll be looking at mine ASAP. Does the fairing vibrate or shake noticeably when they've failed? I've not noticed anythign of the sort but never knew to watch for this. At 87,000 miles I've got to be way past needing to inspect them.
YEAH MOST OF YOU GUYS ARE IN THE SAME BOAT AS ME BUT MINE WENT SO LONG THAT IT KILLED MY HARMAN KARDON CD PLAYER. IT HAS A MIND OF IT'S OWN NOW AND TURNS ON ALL THE TIME BUT I LOST SOUND. AND IF I TURN IT(HANDLEBARS) TO THE RIGHT IT TURNS ON AND SOUND COMES OUT 7 OUT OF 10 TIMES OF POWERING UP. I'M AN MMI GRAD AND I SHOOK ALL THE WIRES DOWN/CLEANED AND GREASED THE PLUG WITH DIALECTIC GREASE/CHECKED THE CONNECTORS AND COULDN'T FIND THE PROBLEM AT HAND WHEN I HAD NO SOUND. SO I CALLED THE DEALER AND THEY TOLD ME THAT IT IS VERY,I REPEAT VERY, COMMON FOR BROKEN BRAKETS TO JUST MURDER THE STEREO. I BOUGHT MINE WITH A SALVAGED TITLE SO THE WARRANTY DO SQUAT FOR ME FROM THE STAND POINT OF MOTOR PARTS FROM HD. BUT THE GOOD NEWS IS MY DEALER WITH I HAVE A EXCELLENT BOND WITH TOLD ME THAT THE HK STEREOS WERE SO PROBLEMATIC THAT HD DOESN'T DEAL WITH WARRANTY ISSUES THAT THEY ARE NOW SENT TO THE MANUFACTURER. SO I MIGHT GET A REFURBED RADIO OUT OF THIS DEAL TOO. I'LL KEEP YOU POSTED. AND IF I DON'T OH WELL I'LL GO TO www.HAWG-WIRED.COM AND GET THE INSTALL KIT FOR A SONY THAT YOU CAN USE YOUR CURRENT RADIO CONTROLS WITH. BEATS SPENDING TONS OF MONEY FOR MORE TROUBLED PARTS. DON'T GET ME WRONG I'M IN LOVE WITH MY CUSTOM STREET GLIDE BUT I CAN'T WAIT TO FINISH MY HONDA OLD SCHOOL CHOP. VERY LITTLE ELECTRICAL AND AND A KICKASS SCOOT FOR UNDER $2000!
KEEP YOUR KNEES TO THE BREEZE AND RUBBER SIDE DOWN JON @ TURDS GARAGE
Pulled the front farring to day and found all four brackets broken.
Went to dealer for a price small bracket 16.00$ each Vertical bracket 68.00$ each
Aprox 170.00$ with 10% discount. for all four brackets.
Went back home and got the welder out, took some time but they are now repaired. Welded a "L" bracket to the top for extra strength painted it black and will have it back together tomorrow just in time for the RAINNNNNNNNNNNNNNNNN. Boy did it feel good to save 170.00$ Now I can buy more CHROMEEEEEEEEEEEEEEEEEEE.
William Southern Ontario Canada
On the other hand, the fairing is shaking big time as of yesterday. I think I may have broken fairing mounts now.
Same with me, Have 22000 miles and the inner fairing supports broke at the 90 degree bend where it bolts to the top off the inner fairing. To the right and left of the speedo and tach. Bought (2) 90 degree angle brackets from farm and fleet and (4) 1/4 inch 20 thread allen head bolts and locker nuts and drilled into the support. $4.35 later and 500 miles and everythng is looking good.
I had my front faring off this weekend to fix a couple of broken wires and I notice that the support brackets were broken in 6 places, 3 on each side. I have heard of this happining a lot but what if any is the Motorco doing about this. I cked the price and it looks like to replace the brackets would be around 120bucks. Does any one know it the motorco is doing any thing about the broken brackets?
I didn't see it in this thread. Could you link us to this message?
Watch out folks, a stiffer bracket sounds great, but it may transfer the load into another component which will then break. i'd suggest sticking iwth the new HD component which should be tested thru vib and shake test to insure they don't damage something else.
