She's Weeping! But why?
Old 12-29-2008, 04:49 PM
TRVSDAD's Avatar
TRVSDAD
TRVSDAD is offline
Default She's Weeping! But why?
I seem to have developed a minor weep of oil at the bottom of my front cylinder, just behind the push rod plate. After a hundred and fifty miles or so it looks a little damp. Can be dabbed up with a paper towel. Very strange, just did 20k service. I'm going to check to make sure both breathers to the air cleaner are clear. I hope I won't have to rip top end off to replace a couple of O-rings. Any idea's?
Old 12-29-2008, 05:18 PM
jpooch00's Avatar
jpooch00
jpooch00 is offline
It could be coming from under the lifter block or maybe from the bottom of the pushrod tube at the o-ring seal. Hopefully it's not the cylinder base gasket. Do you let the motor warm up a little while before you ride? That will help your cylinder base & head gaskets last.
Old 12-29-2008, 07:13 PM
jag1886's Avatar
jag1886
jag1886 is offline
If it's that miner why are you worrying about it???????
Old 12-30-2008, 01:41 PM
TRVSDAD's Avatar
TRVSDAD
TRVSDAD is offline
I let the bike warm up completly before every ride, but it has been extra cold here lately 50 degrees upon startup. "Jag1886" I'm neurotic I hate oil leaks on anything I own. Push rod tubes are dry I'm pretty sure its coming from the O-ring at cylinder base.
Old 12-30-2008, 02:39 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
I'll bet it is coming from somewhere other than the cylinder base. Base gasket leaks are kinda rare on Twin Cams.
Old 12-30-2008, 02:55 PM
TRVSDAD's Avatar
TRVSDAD
TRVSDAD is offline
xxxflhrci, any idea's?
Old 12-30-2008, 02:56 PM
rbabos's Avatar
rbabos
rbabos is offline
Sometimes they leak oil at the head gasket, travel down the stud holes and show up on the outside of the base o-ring even though the base ring is pefectly fine and doing it's job. Look up at the head gasket as see if it's dry up there. It still may not show it, as it hasn't reached the outer part yet. Short of that, clean it all off, ride short distance and see if you can find the first tell tail sign. If that shows nothing except a wet spot at the base, pm me and I'll explain how to test the head gasket.
Ron
Old 12-30-2008, 03:05 PM
TRVSDAD's Avatar
TRVSDAD
TRVSDAD is offline
10/4 will do, and thanks. I used to be in the air conditioning business and we could add a red dye to the freon and you could find leaks pretty easily. I removed the air cleaner last Saturday and got in there with a flashlight and felt around with my fingers and havent found any oil any where except at that base and it migrates between the cylinders and over to the left side as well after 200 miles.
Old 12-30-2008, 06:47 PM
racklefratz's Avatar
racklefratz
racklefratz is offline
"miner"....WTF is "miner"? We talking about mining here?
Old 12-30-2008, 07:35 PM
DanDil's Avatar
DanDil
DanDil is offline
I had a leak and it was coming from where the clutch cable entered the trans. the oil was rolling forward along the cable and dripping off about 10 inches forward of the trans
1985Cowboy19
Engine Mechanical Topics
08-20-2018 06:04 AM
mostSilly
EVO
08-03-2010 10:10 PM
the_ogre25
EVO
16
05-21-2010 05:42 AM
Bama Harley
Exhaust System Topics
07-25-2006 02:27 AM
turbo54
12-14-2005 03:35 PM
Quick Reply: She's Weeping! But why?
