Bubbles from block / Cylinder
Old Aug 3, 2010 | 08:02 PM
mostSilly's Avatar
mostSilly
Default Bubbles from block / Cylinder
So, this seems like a no brainer - but ithought i would get a second, third, opinions - on the rear cylinder, from where it mates to the block, i get bubbles while running, and sometimes after shutting down for a bit. Seems like i need to check the torque on the heads right? It doesn't always do it so its kinda throwing me off.
Old Aug 3, 2010 | 08:07 PM
ajayrk's Avatar
ajayrk
Leaking base gasket. Replace it with a steel aftermarket gasket.
Old Aug 3, 2010 | 08:11 PM
mostSilly's Avatar
mostSilly
Would you consider that a reason to park it till repaired or put it off a few months till winter be ok?
Old Aug 3, 2010 | 08:57 PM
miacycles's Avatar
miacycles
As long as the leak doesn't bother you ride it until the cold weather hits.
Old Aug 3, 2010 | 09:04 PM
mostSilly's Avatar
mostSilly
Thank You for the Input!! I was worried that there may be something else that would cause major grief right around the corner if i didn't take care of it quick -
Old Aug 3, 2010 | 09:56 PM
Jim Kraft's Avatar
Jim Kraft
Always let it warm up for a little while before you ride. The heat expands the cyl. and seals the gaskets. If it was mine, I would just keep riding it until it starts blowing oil out bad.
Old Aug 3, 2010 | 10:10 PM
RidemyEVO's Avatar
RidemyEVO
Ahhhhh not the winter word already.
Ride it and get HD head gaskets and James base gaskets for down the rode.
raconteur99
Engine Mechanical Topics
Jul 16, 2014 06:56 AM
avnsteve
Nov 12, 2013 08:05 AM
the_ogre25
EVO
16
May 21, 2010 05:42 AM
WARG
Mar 24, 2008 11:57 PM
Naz_Man
Jul 18, 2006 01:42 AM
