removing ingnition "key" off FLHTC
I am trying to removing my inner fairing to get to the top of my forks on my '02 Electra Glide Classic so I can eventually change the fork oil and install my new lowering kit. I have the manual, and it says to push that tab on the inderside of the key up, then turn the **** 60 degrees and it should come off the stud it's on?? I can't for the life of me get this thing off?! Any suggestions or tricks with help getting it off?? Thank you
If I remember right this is how we did it on my dads 03, turn the switch to accessory, with the key in the ignition and while pushing the pin in, turn the KEY back counter clockwise and pull up, it should come off. If this is wrong sorry, also use the SEARCH button and type in ignition switch. Hope you get it off.
Thanks guys, I am going to retry it.......yeah it says in the book to turn to acccessory, but I didn't have the key in the ignition, I just had it unlocked. I will try tonight to do it with the key in the ignition.
I did a search, and after reading through some, it sounds like putting the think back on is a pain in the a$$?? Is it?
reinstall is not bad once you get the hang of it. Look carefully at the piece that comes off the bike... you will notice the nubs on one side are square-ish, the other side is dovetail shaped. For lack of a better word, this is like the 'key'. the 'lock' part, still attached to the bike, has to be lined up with the 'key' to work right. With the ignition switch removed, these 2 'locks' will rotate independent of each other, and must be lined up so it goes back together properly. Search your toolbox to find the right sized flat screwdriver that will allow you to rotate the bottom 'locks' independent of the top one... shining a flashlight down in the hole, make sure that both dovetail 'locks' are lined up at the 2:00 position. Then with the ignition lock pointing toward the "Lock" position, it should slide right in place. IIRC the bottom 'lock' piece down in the hole controls to the fork lock if you accidentally lock the forks over and need to move them, you can move this one and the forks will release.
if you study the nubs and their position on the ignition lock while is out, this will make more sense.
p s do not stick any thing down in the switch to line anything up when you
go to put the **** back put it back [JUST LIKE YOU TOOK IT OUT] with the ****
over on fork lock and key in and turned 60 degrees counterclockwise and it will
drop right back in turn key clockwise and it will lock in
One caveat: When you remove the odd-shaped nuts and washers under the **** that hold the fairing cap on, don't reinsert the switch shaft and **** and change its position unless these washers are in place. If you do you will likely get the tumblers out of sync and you'll have to futz around with them with a flat-blade screwdriver. It's no fun so be careful.
