retrofit PC-V or PCIII for 08 RKC
I am undecided on which way to go on this. The fact that Dynojet doesn't offer a warranty or anything for 08's sort of scares me. I would order the PC-V from Jamie at Fuel Moto like many of you have. Does anyone have any feedback on one of the retrofit models?? I will be installing Rinehart true duals and a stage 1 filter at the same time.
Fuel Moto both double-warrants (two years) and supports all retrofit models with the knowledge and blessing of Dynojet. IMO warranty is a non-issue and would recommend the PCV since it is smaller, newer technology, has more features, allows map switching without an expensive add-on module (hub), and you can upgrade to Auto-Tune later if you want. The price for the PCV is about $20 more.
As you are running now you have a good intake/exhaust setup but also very lean AFR's, which affects cooling and performance.
If you decide to buy from Fuel Moto be sure to tell him you have the Stage 1 download so he can load the correct map in the PCV.
Dynojet offers a 1 year warranty which we double, giving you 2 years of warranty coverage. Also note it is very important if you have the IED's to remove them before installing the PC-V
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
