Diode for tail light conversion
Old Mar 10, 2009 | 07:54 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Default Diode for tail light conversion
I have two stop lights and each having its own turn signal. Does anyone know of a "diode black box" that plugs into our factory harness that allows standard two wire automotive syle lights to be wired out of it? Here is a photo of what I have. The problem is the HD harness has a separate brake and turn signal wire. My lights are dual LED's, 2 wires, plus a ground, one lamp for running and the other for stop/turn.
Old Mar 10, 2009 | 09:38 PM
timberland's Avatar
timberland
To The Top because I need to know, LOL....Did a little research. What I am looking for is the guys that tow trailers behind their HD's, what electronic box do you use to convert the 5 wire HD harness to a 4 wire for the trailer lights?
Old Mar 10, 2009 | 09:49 PM
09StreetGlider's Avatar
09StreetGlider
Use the Badlands illuminator run brake turn module. Then wire both lights into the turn signal harness. They will act as run brake and turn.
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm
Old Mar 10, 2009 | 10:23 PM
jdreed520's Avatar
jdreed520
Or you can just get the diode Y wire set from Radianz......That is what i have used...
Old Mar 10, 2009 | 11:21 PM
desertclassic's Avatar
desertclassic
Ride Time Technology makes a harness that allow for light conversions. It just plugs into the harness under the seat. I have one on the way to change out the lights on the ultra. About 45$. Keith will set you up with what you need.
http://www.ridetimetechnology.com
Old Mar 11, 2009 | 02:58 AM
Harleypingman's Avatar
Harleypingman
I used the HD run/brake/turn signal module (that HD sells to plug between the connectors under the seat at the rear fender) and spliced into the brown and violet turn signal wires (that control the rear turn signals) with a power wire from each of the HD saddlebag spoiler LED's in order to make the saddlebag spoiler LED's function as run/brake/turn signal lights. I also spliced the ground wire from each saddlebag LED to the ground wires from the module. Has worked fine for 2+ years--the turn signals worked as run/brake/turn signals and so did the saddlebag LED's, with no loss of brightness--they functioned identically to my buddy's turn signals and saddlebag LED's except that my saddlebag LED's also worked as turn signals.
Good luck with your project.
JacobEF
Electrical/Lighting/Alarm
Oct 27, 2019 07:47 AM
oneshotdog
May 25, 2017 11:34 AM
Branstner
Jan 15, 2017 12:31 PM
xIceHoundx
Jun 14, 2016 09:14 PM
hdstevie
Jun 27, 2015 01:46 AM
