Spotlight wiring question
Old Mar 27, 2009 | 10:13 PM
2VV's Avatar
2VV
OK, This is not going well, I did exactly what I found out later not to do:
One caveat: When you remove the odd-shaped nuts and washers under the **** that hold the fairing cap on, don't reinsert the switch shaft and **** and change its position unless these washers are in place. If you do you will likely get the tumblers out of sync and you'll have to futz around with them with a flat-blade screwdriver. It's no fun so be careful.
How do I get the tumblers to line up right to make the switch work properly, I have not power now. Live and learn I guess.
Old Mar 27, 2009 | 10:18 PM
saxmanbill's Avatar
saxmanbill
Originally Posted by mymatrix
Can you share the part number you ordered?
Did you use a boot for weatherproofing?
McMaster-Carr part numbers are: 7172K23 for switch and 70205K26 for the boot. $12.09 for switch and $3.37 for boot. Go to mcmaster.com and search for toggle switch. They have locations in Atlanta, Chicago, Cleveland, L.A., and New Jersey. When I order stuff for work it usually arrives the next day.
Old Mar 28, 2009 | 02:47 PM
2VV's Avatar
2VV
GOt it, searched past posts on the topic, it needed to be done perfectly, otherwise woud not go. Thanks, Kevin
Baloofalo
Apr 19, 2018 01:36 PM
luckyfdr
Mar 19, 2013 06:51 AM
ACLazer
Mar 12, 2012 07:15 PM
usmc3468
Feb 12, 2011 08:03 PM
Willy G.
Sep 20, 2009 06:54 PM
