07 SG BIG RADIUS ??'s
Old May 1, 2009 | 06:12 PM
Smyln's Avatar
Smyln
Default 07 SG BIG RADIUS ??'s
I have an 07 Streetglide with EFI.
Currrently running V&H Slipons, Stage 1 AC and HD download
I want to put Big Radius 2into2. I prefer to run with the baffles out. Since I have to have the bike dyno'd
Will they be able to tune it to compensate for not having the baffles in?
How much is a Power Commander V?
Should I get Torque Cones?
Thank you
Old May 2, 2009 | 06:58 AM
Smyln's Avatar
Smyln
Hasn't anyone purchased a Power Commander V?
Has anyone elsed used the Torque Cones?
Does everyone run with their baffles in?
Old May 2, 2009 | 08:45 AM
cryan9's Avatar
cryan9
I love my Big Radius but I wouldn't run them without baffles. You will lose power and it sounds horrible when you let off the throttle. If you want them to be extra loud without the negative sides of running without baffles, get the Thunder Monster Baffles from Big City Thunder. The power is good and the sound is amazing. With the BCT Thunder Monsters, you get pretty close to the sound of running without baffles but no fluttering sound when you let off throttle. I wouldn't run any other pipe combination if someone paid me to.
Old May 2, 2009 | 08:48 AM
OregonFXSTC's Avatar
OregonFXSTC
If you have the Big Radius pipes and Stage one, and SE Tuner and install Thunder Monster Baffles do you have to re-dyno after installing the Thunder Monster Baffles?
Old May 2, 2009 | 09:09 AM
cryan9's Avatar
cryan9
No you don't as long as your bike was tuned for the pipes that you are installing them on. My bike was tuned for the Big Radius pipes with stock baffles. But runs better now with the Thunder Monster baffles without being re-tuned. The first sentence on this post is what the representative from Big City Thunder told me and from how my bike is performing now, is an accurate statement.
Old May 2, 2009 | 09:11 AM
OregonFXSTC
thanks
Old May 2, 2009 | 09:19 AM
rideshack's Avatar
rideshack
Former Sponsor
You will lose torque, as well as have decel backfire issues, if you run without the baffles. Torque cones can help a small bit, but I think you will still regret running without the baffles.
Unfortunately, the Powercommander V is for the '09 models ONLY. I have the Thundermax on my '07 SG, and I absolutely love it. It's a closed loop fuel system, which compesates for changing conditions. It targets the air/fuel ratio coming out of the engine rather using a static "map". I never think about my fuel injection when I make changes to my exhaust, air cleaner, or engine. It's nice.
Corey
magnum629c
Mar 23, 2014 10:55 PM
hd4l
Sep 26, 2013 04:18 PM
Dyna346
Sep 25, 2012 10:26 PM
paul987
Apr 22, 2011 12:15 PM
09B29
Nov 17, 2009 11:00 PM
