@#$@ Fairing Bolts -- Help Please
Old May 5, 2009 | 10:14 AM
Modee1245's Avatar
Modee1245
Default @#$@ Fairing Bolts -- Help Please
I was attempting to remove my fairing in order that I may install my new fairing mount mirrors. I got 3 of the 4 out. As luck would have it, the 4th one is stripped in the head therefore, I can not turn it to get it out.
Does anyone have any suggestions on how to get it out?
Also, would you switch screws to something different like flat head or phillips..
Thanks...
Old May 5, 2009 | 10:16 AM
Our07Ultra's Avatar
Our07Ultra
I have a tool called an easy out that works real well under these circumstances. Im not in my garage but will try and look up some info for ya
Old May 5, 2009 | 10:17 AM
Ribitt's Avatar
Ribitt
Cool
Drill and small easy out then change them all out with stainless steel allen heads.
Old May 5, 2009 | 10:22 AM
jdreed520's Avatar
jdreed520
+1 for Ribitt...that is exactly what i did.
Old May 5, 2009 | 10:29 AM
honestbob's Avatar
honestbob
The most important thing with torx heads is to use the RIGHT size tool! If it's got play in it go to the next larger size. It's easy to strip them out with a smaller size.
Old May 5, 2009 | 10:46 AM
Bushy's Avatar
Bushy
Sears has a EZ out tool for about 20 bucks, worth the money. many practical future uses
Old May 5, 2009 | 10:52 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Torque(Star) Head #27 is the proper bit to use.
Also, buy an in/lbs torque wrench and torque them to 25 in/lbs when you re-install them.
First time I did it by feel and the bottom screws were fairly loose the next time I went to remove them.
Old May 5, 2009 | 01:27 PM
Modee1245's Avatar
Modee1245
Thanks guys..
Old May 5, 2009 | 01:29 PM
oldhippie's Avatar
oldhippie
PS if your inside the fairing check your fairing brackets.. they break at the top. the black vertical ones.
Old May 6, 2009 | 11:16 AM
Modee1245's Avatar
Modee1245
Got it out,,, thanks for the help...
