2009 burning Clothing
Old Jun 9, 2009 | 12:51 PM
jeepmanjeff's Avatar
jeepmanjeff
Default 2009 burning Clothing
I have a 09 Ultra. This has stock exhaust on it with slip ons and tuned. I ride to work every chance I get in dress clothes. I have now burned through 4 pairs of dress pants from the exhaust that is located by the floor board. I am 5'9" and have road for years on Harleys and have never had this happen till the new bike.
Any suggestion would be greatly appreciated. (IE)
Do I change to different exhast that has a smaller pipe on it?
Seems the place I am burning at is where the from and rear pipes come together into 1 before the cross under. It is a bigger diameter there.
Old Jun 9, 2009 | 12:59 PM
beary's Avatar
beary
Interesting, I know that I will be dressing the same way soon to work and will have the same problem. I do wear my boots and change into my shoes at work, but I'm not sure that will help here. Are there gators made for bike riders, kind of like what is used in backpacking? Quick and easy to take off and put on.
Beary
Old Jun 9, 2009 | 01:00 PM
JustDennis's Avatar
JustDennis
I also ride to work each day. I wear chaps both for the protection in case of a fall and also to protect my pants. I also have a set of textile overpants that let a lot of air pass thru but I have found the chaps work fine even during the warmer months. I also leave a pair of dress shoes at work. I take my boots off and put on the shoes, remove the chaps and comb my hair and am good to go.
Old Jun 9, 2009 | 01:05 PM
jeepmanjeff
I have chaps too but in 90 degree plus weather in OH mid afternoon it is REALLY HOT.
I just ordered BUBS True Duals for it. This will decreese the heat and hav a smaller pipe also for it. I will recoop my money from not buying pants.
Old Jun 9, 2009 | 01:10 PM
pidnaul's Avatar
pidnaul
This is where the cat is located on the 09 bikes. The cat will dramatically raise the EGT's when it does its job of burning the extra HC's. Getting rid of that furnace will help a lot.
Old Jun 9, 2009 | 01:12 PM
carpetride's Avatar
carpetride
just do it Michael Madsen style
Old Jun 9, 2009 | 01:18 PM
cuda67bnl's Avatar
cuda67bnl
Floorboard extensions may move you away from the pipe just enough? I'd recommend harleygoodies if you choose to give that a try.
jeepmanjeff
I did not thik that my bike had a cat on it because it is in OH not Cali. If this is the case then it stands to reason why it is so large there and burns shoes and clothing. MAN IS IT HOT!
Can you verify that there is indeed a cat on my bike from OH?
Old Jun 9, 2009 | 01:21 PM
garyhendley's Avatar
garyhendley
PLUS 1 ON THE FLOORBOARD EXTENTIONS-ride safe
Old Jun 9, 2009 | 01:30 PM
jdreed520's Avatar
jdreed520
I use chaps to cover my dress pants when i ride to work which is often no matter how it is outside......and the suggestion about floor board extensions...hmmmm I might have to try that..........
