Which luggage rack should I get?
There was a thread not long ago and a member was not happy with the stealth regarding it did not hold a bag well? Anyway i have also heard issues with the one that attaches to the backrest.53011-98,Not being strong enough.I went with the detach 2-up 53743-97 and could not be happier....I leave it on all the time and i can take pass. backrest off...because they use sep. docking points...This thing is SO strong i can lift the back of my flht to slide it over in garage..DONT TRY THIS AT HOME!!! IM A PROFESSIONAL BIKE SLIDER!!! Any way i see them on C-list or swaps for around $100.00.....Good Luck!!!! R.W.
Received 25,120 Likes
With most luggage racks, you have some sort of rear backrest on when "packed". With the stealth rack being low, my large t-bag sits right down on the rack and I use the straps and a spider net and secure it to the back-rest. It is very strong since it mounts right into the rear frame (replaces the stock grab bar).
For sure, if you are looking to haul something without a back-rest, the stealth is not the way to go. But when I take a trip, even one up, the backrest is used for a solid anchor point for my t-bag and sleeping bag.
For my buck, the stealth has full time looks and function.
08 sg. I have the stealth rack. Here is a pick of mine with the stealth rack right beside another 08 sg without. I have used the stealth rack on two 2000+ miles rides. It worked fine for me. I did have the backrest on while traveling, one trip was two up, one was solo.
Greetings,
I want to get a new luggage rack for my 08 streetglide and don't konw if I should get the rack that attaches to the sissy bar (53011-98) or the 2 up luggage rack (53743-97) which requires the docking hardware. I already have the hardware but have not installed it yet. What are your thoughts?
Sunnenman
Sunnenman
S
