Front tire
Old Jun 3, 2006 | 11:55 PM
TBone's Avatar
TBone
Default Front tire
How hard is it to take the front tire off my RKC? I just need to install a fender rail and it would be a lot easier without the tire on.
Old Jun 4, 2006 | 12:00 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Front tire
If you open your service manual to the section labled CHASSIS, it will walk you through it.......
If not, well, you will need a 10mm 12pt socket, 3/4 6pt, 1/2 6pt, blade screwdriver and small hammer.....
Be sure to tape your fender before you loosen up the calipers.....
Don't want to be scuffing up the paint on the fender when the calipers are loose and you can't get them out correctly.....
bountyhunter's Avatar
bountyhunter
Pull the axle and the calipers (10mm, 12pt). 10 minutes, if ya take your time!
Old Jun 4, 2006 | 12:01 AM
mikeisglidn's Avatar
mikeisglidn
unbolt the calipers and slide em outof the way and drop the axle and wala, your ready to work on the fender............dont forget to use a jack (very important)
Old Jun 4, 2006 | 01:42 AM
capt42a's Avatar
capt42a
Dont forget to use a jack under the rear tire to keep the bike balanced on the lift when you remove the front tire.
capt42a
Old Jun 4, 2006 | 02:58 PM
rdking330's Avatar
rdking330
Nice if you have a jack, then go by your manual, pull the calipers and axle and your there, half hour to do the job, just have all the tools set up and it's always great to take pics of your before and after
MagnumMike52
Feb 9, 2015 09:18 PM
mobsters1972
Mar 19, 2014 02:22 AM
JohnK-NJ
Dec 9, 2013 05:20 AM
98glider
EVO
11
Apr 10, 2011 10:26 PM
HarleyMom883
Sep 26, 2007 10:42 PM
