Satellite Radio Suggestions
I have the same setup with sirius and have gone thru 3 radios. Apparently the vibration has loosened the antenna connection in the radio itself, not the mount. I'm on my 4th and I stepped up to a stratus 5 and so far it's holding out. If the XM's have no problem, I may switch if it happens again.
I just transmit the sat radio sig over FM at 91.7MHz and don't use the cable...probably does not sound as good as the hardwired connection...
B.
Currently using a Pioneer Inno2. Works good no problem with reception unless going under an overpass. I use it just about everyday. Great for when I get to work just unplug it and take it into the office and plug into the home cradle. Then plug it back in for the trip home. Then plug it in again at home.
I do use a small amplifier that I bought for headphones which increases the output to the head unit.
