Accessory switch?
Old Aug 27, 2009 | 05:23 PM
quigley's Avatar
quigley
Default Accessory switch?
The accessory switch on the dash is powered by the plug under the seat. The plug has 4 pins numbered 1 thru 4. Does anybody know which # pin controls the switch and what are the other 2 pins for?
Thanks Quigley
Old Aug 27, 2009 | 06:54 PM
spartns's Avatar
spartns
Actually, you've got it backwards. The switch controls the plug.
Old Aug 27, 2009 | 06:58 PM
quigley's Avatar
quigley
Ok fine, the switch controls the plug. Any other words of wisdom pertaining to my question?
Quigley
Old Aug 27, 2009 | 07:08 PM
Ultra89Rider's Avatar
Ultra89Rider
The 4 wires are as follows.
Pin 1, Orn/Red - Switched (Acc. Switch)
Pin 2, Red/Yel - Brake Light
Pin 3, Orn - 12 Volt switched (Ign.)
Pin 4, Blk Ground
Old Aug 27, 2009 | 07:14 PM
quigley's Avatar
quigley
Pin 4, Blk Ground
Thank you very much!!!
Quigley
Old Aug 27, 2009 | 07:19 PM
quigley's Avatar
quigley
This maybe a dumb question but, why is there a brake light wire in the accessory plug?
Quigley
Old Aug 27, 2009 | 07:28 PM
Ultra89Rider
Quigley
That way if you want to add extra brake lights in addition to running lights, you have a wire ready.
Old Aug 27, 2009 | 07:30 PM
quigley's Avatar
quigley
That makes sense, learn something new everyday, Thank You
Quigley
Old Aug 27, 2009 | 07:37 PM
Clint55's Avatar
Clint55
You know......... I'll bet you could even use the acc switch to power a bigsky fan!
Old Aug 27, 2009 | 07:43 PM
quigley's Avatar
quigley
Very good idea!
Quigley
