Need a little advice about Gerbing Heated Gear
Well, I finally broke down and bought a pair of G3 heated gloves for this coming winter. I have arthritis in my hands and am sure this will help in cold weather riding conditions. I get the jacket liner before cold weather sets in.
I have a question regarding locations where and how to mount the permanent dual temperature controller? I thought this would be the best set up but maybe I should have considered the portable ones.
Any advice and pictures of your installations will be greatly appreciated.
TIA,
Charlie
TIA,
Charlie
I put the dual controller in my left coat pocket, with the ***** pointed up. I can take my fingers and adjust the temps pretty easy with the gloves on. The single wire from the battery comes out from under the seat in the front between my legs. It makes it easy to connect when mounting the bike.
If the inside portion of the switches aren't too deep, you could mount them in the two blanks on this switch housing.
I thinking the best spot might be where trail said, on the lower right side of the inner fairing. The switch housing looks good but I don't have any blanks. There is not enough room on the outside of the right/left switch either.
To those that have them, do you fiddle with the temp control a lot? If I need to get at it all the time it will definitely make a difference where I mount them.
I have the dual portable controller on my Road King. Mounted it on the tank console right in front of the seat with double adhesive velcro. Battery pigtail connector comes out under the seat and plugs into the controller. ***** point to the left so can be easily adjusted.
All of it is easy to remove in the summer when not used.
