Timkin question
Old Sep 24, 2009 | 02:26 PM
Born2cure's Avatar
Born2cure
Default Timkin question
Doing a 103 kit have approx 15000 miles on my 08 ultra would it be recommended to do the timkins now and pay the extra labor or will it be good.
Thanks
Old Sep 24, 2009 | 02:32 PM
FLHTCU Owner's Avatar
FLHTCU Owner
I've always heard it's wise to go ahead and change them while your there. I'm going to change out my stock cams this winter and will be changing the bearings as well.
Old Sep 24, 2009 | 02:36 PM
07RoadHawg's Avatar
07RoadHawg
I assume you are talking about cam bearings? If so, there really shouldn't be much labor (if any) involved while the cam chest is apart. Like FLHTCU said, it's never a bad idea to change the bearings, especially given the minimal cost.
Old Sep 24, 2009 | 02:41 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Torrington B-168's is what you'll need for inner cam bearings if this is what you're referencing. Easy peasy with the right tool and I'd suggest it as well. I changed mine!
Old Sep 24, 2009 | 02:50 PM
ryanl's Avatar
ryanl
Inner cam bearings?
Yes. Torringtons as mentioned.
Timken Conversion?
That would require you to split the cases. You have an 08 so there is no reason you need to split the cases to make 103, unless you want to do the timken. And if you are going with the dealer installed SE setup, there is a good chance you wont make enough power to have to worry about it.
If doing a build where you need to split the cases anyway, to bore cases and swap cranks. I would do it without hesitation.
09B29
Exhaust System Topics
Nov 13, 2011 07:45 AM
rkoivisto
Nov 23, 2010 05:16 PM
1fathog
May 23, 2010 08:43 PM
harleyman1340
Apr 6, 2010 08:04 PM
kansasroadking
Jul 12, 2007 06:19 PM
