6 Gallon for a 5 Gallon Tank
Old 10-12-2009, 10:12 PM
cchips's Avatar
cchips
cchips is offline
Default 6 Gallon for a 5 Gallon Tank
May not be the right forum, but since I have to replace the tank anyway, does anyone know if the new 6 gallon tank will fit on a 2007 Road King Classic? I would certainly like the extra gallon.
Old 10-12-2009, 11:18 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
I asked this question last week, I guess it's not an easy change over.
https://www.hdforums.com/forum/touri...-08-model.html
Old 10-13-2009, 05:39 AM
smokindave's Avatar
smokindave
smokindave is offline
My 08' has the same frame with the 6 gal tank. That's a good question and right now I don't see why it wouldn't fit. I wonder if the seat will be a problem.
Old 10-13-2009, 12:15 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
Mounting is differant
Old 10-13-2009, 01:21 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
Wait till you get old and your prostate reminds you of your age. You'll be stopping sooner than a 5 OR 6 gallon tank fill-up.
nobodyknowsme (09-14-2018)
Old 10-13-2009, 02:34 PM
Trailfndr's Avatar
Trailfndr
Trailfndr is offline
Seat will also have to be changed. It mounts differently on the 08 then it did on the 07. The slot and tang in the front are reveresed with the larger tank.
Old 08-06-2018, 12:11 PM
Cricket11's Avatar
Cricket11
Cricket11 is offline
well, you're half right. The front half of the 08 frame matches the 09 models, and the rear half matches the 07 bikes. The area under the back of the tank is sunk in for the additional wires to fit under it, I have successfully swapped tanks by spreading the wires out, and covering with wide electrical tape. Spacers will need to be used on the front mount to make up the width difference, and the rear will need to be drilled and tapped where the tank sits. Then an 08-newer seat will fit. Then, the float level will read different, because the electronics changed between 07 and 08. Get the newer gauges, you should be fine, that's what I did. The wiring from the 07 plugs into the 08 if you have the 08 tank harness.
Old 08-06-2018, 12:58 PM
jimglassford's Avatar
jimglassford
jimglassford is offline
I am not sure if the swap is necessary. It has been noted on a lot of discussions on the capacity of the 6 gallon tank. I have a 2011 and after the low fuel level light comes on, I can get maybe 4 to 4.5 gallons i the tank. This has been noted by a lot of people.
Old 08-06-2018, 01:08 PM
ORradtech's Avatar
ORradtech
ORradtech is offline
Probably due to an inaccurate fuel float rather than tank capacity...
One reason I set a trip guage at every fill up.
Old 09-13-2018, 08:55 PM
AIR_RAM's Avatar
AIR_RAM
AIR_RAM is offline
Posted in wrong section...
Quick Reply: 6 Gallon for a 5 Gallon Tank
