Spark plugs /Anti-seize
Old 10-19-2009, 07:47 PM
TheJimer's Avatar
TheJimer
TheJimer is offline
Originally Posted by harley-jones
Steel threads/aluminium heads...Anti sieze is a must IMO.
Your opinion is absolutely, 100%, dead nuts correct!!!!!!!!!!
Old 10-19-2009, 07:49 PM
dawg's Avatar
dawg
dawg is offline
Received 3,002 Likes on 1,731 Posts
Originally Posted by TheJimer
.... about a half a dozen owners have reported galling their pugs upon removal!
I would imagine that pulling a dog out of a spark plug hole would cause a hell of a lot of galling!
Anyhow, just don't put antiseize on the bottom two threads to ensure it is kept away from the tip.
Old 10-19-2009, 07:50 PM
SteveO's Avatar
SteveO
SteveO is offline
Use sparingly. Only put it on the upper 2/3 the plug threads. It will run when hot and foul out a plug.
Steve
Old 10-19-2009, 08:34 PM
My Fix's Avatar
My Fix
My Fix is offline
Talking Anti-sieze ?
For the machinist out there , most will agree ! Typically 5 threads will hold anything the bolt will hold . Spark plugs threads are a little diffrent , the threads on a spark plug are just under size ! The theory is for the spark plugs to be handy , thats why there is approx 12-15 threads on a plug ! Them being handy means you would need more threads to prevent pulling the threads out . Or on hi compression motors , blowing a plug out . I'm a machinist for budwieser and have raced on numerous accounts , outboard drag boats , modified dirt track ,and dirt bikes ! 35 years of racing and ain't never had any issues with threads on plugs . I dont care how hot it gets ! I have installed every plug I have ever put in dry . Most thread problems are from wire brushing the end of the plug , and causing ruffing up on the first two threads . This will cause a gaulling when going in , feels like sand on the threads ! Other problems is most folks tighten them way to tight ! Typical spark plug with the compression washer will seal with approx 20-25 lbs of torgue . Down here in the deep south , some of them cajun boyz put that anti-seize on them plugs for corrosion purposes . But if you want anti-sieze on your plugs , by all means do it . just use very little ! That stuff will ruin a set of rings right quick . Just my 2 cents and past exp ! Hope this helps !
Old 10-20-2009, 02:14 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Amen.
MikeSz
10-25-2018 05:11 PM
bobalew
General Topics/Tech Tips
03-18-2013 05:20 PM
JONNIEROCK
11-04-2011 07:53 AM
boblkat
04-11-2011 07:13 PM
corona
Exhaust System Topics
03-05-2007 08:34 PM
Quick Reply: Spark plugs /Anti-seize
