Built a GPS Mount @ 4am - couldn't sleep...
They say you're supposed to read if you can't sleep - well I really wanted a GPS mount before heading out this weekend with my Pappy on a 3day ride through the Hill Country...
Made it out of a strip of 3/4" Aluminum Flat Bar... and two self tapping screws (pre-drilled the holes though).
For the 3/8" nut and bolt in the center of my Windshield - I tapped the mounting hole on the Aluminum Bar to be able to snug it up and use the 3/8" acorn nut like a double locking nut with just a touch of Locktite... also I put some Industrial Strength Velcro on the mounting side of the Aluminum to keep it from rubbing the Chrome - Felt would also work but maybe not as sticky.
It is a bit bouncy at idle - so I will build a brace when I get more flat bar - for this trip it will have a micro-fiber tightly rolled and wedged behind it...
It looks good. I see one possible concern in the design. It looks like the GPS has an arc'd shape on the top and back. If the GPS vibrates and slides to the side a little, could it loosen up enough to fall out? I'd hate for you to see it bouncing down the hwy next to you.
Looks great! I've been working on designing a mount that would attach to the windshield. When you get back from your trip I'd be very interested in hearing how the vibration factor is mounting to the shield.
I'm looking at a shorter extension off the shield but am very interested in your experience.
Safe trip.
Safe trip.
