Running Rich
Old Nov 24, 2009 | 07:04 AM
tx-skydiver's Avatar
tx-skydiver
Default Running Rich
My 08 UC is apparently running rich...but only on one side. If you look in the tailpipe, one is black, the other is grey. Also, the one has turned the pipe into a yellowish hue. The other side is perfect.
I have a SE Stage 1 programmer on the bike.
Is this something I can adjust or does it need to go to the dealer?
Old Nov 24, 2009 | 07:31 AM
huffhuff's Avatar
huffhuff
very little goes out the left side pipe. the scavenge effect of the front and rear cylinders directs the most flow out the right.
Old Nov 25, 2009 | 05:37 PM
tx-skydiver
Thanks Huff. So if I am hearing you correctly, this is normal behavior and I have nothing to be concerned with?
Old Nov 25, 2009 | 06:19 PM
emwolb's Avatar
emwolb
yes, it's normal. look at your headers, they flow mostly out of the right muffler, with the left flowing a small percentage, but nowhere near what the right pipe flows. that's why the right muffler is darker inside than the left. totally a normal situation. it almost works like a 2 into 1 system, with the left muffler being there just so it looks balanced. the left does flow a bit of exhaust, but about 2/3rds of it, i'd say, flows out of the right pipe. when you start it, while it's cold, cup a hand over each muffler end and you'll see what i mean. it's a good system and it does work well. don't be concerned, because it's normal.
Old Nov 25, 2009 | 06:33 PM
tx-skydiver
Sounds good. Thanks for the info.
Old Nov 25, 2009 | 07:13 PM
emwolb's Avatar
emwolb
you're sure welcome tx-skydiver. i think one of the reasons they kept two mufflers was so they could keep the look of twice pipes. the stock headers are quite efficient, it's the mufflers that sorta suck. unless you like your bike to sound like a 79 buick. i'm using rinehart slip ons, and there are many types of slip ons available, easy to install, and they do improve the sound to a satisfying level of sound. glad i was able to be of some help. happy thanksgiving.
Old Nov 26, 2009 | 08:31 AM
tx-skydiver
I currently have the ThunderHeaders and absolutely love those pipes. I just wish I could get them to not turn yellow. Oh well. The sound is worth it and the saddlebags hide most of it.
Old Nov 26, 2009 | 08:50 AM
1999E-Glide's Avatar
1999E-Glide
My Vance and Hines pipes haven't turned yellow, but my downpipe out of the Rear Cylinder is yellowing. Front looks fine. I still have the factory headers and pipes out to the mufflers. After christmas gonna buy some Vance and Hines Duals and keep my mufflers. Will see then if it makes a difference. I guess the rear cylinder gets hotter and runs a little leaner than the front.
feuysal
Exhaust System Topics
Nov 1, 2018 08:40 AM
pab
Milwaukee Eight (M8)
14
Feb 1, 2018 05:29 PM
Bohemka
Apr 3, 2015 04:31 PM
shore
Nov 6, 2010 12:31 PM
ConradM
May 24, 2009 06:27 AM
