Where to mount accent lights
Old 12-02-2009, 07:24 AM
locodude's Avatar
locodude
locodude is offline
Default Where to mount accent lights
I've got an 09 ultra and I've got a set of electropods coming which consists of six pods and two light strips. I've been looking around the bike and I'm thinking two pods in the air cleaner and one or two in the horn cover and the strips on the bottom of the floorboards. that leaves me two pods left and I'm not sure where to mount them, I'm thinking under the tank but they would be visible and I don't want that. Where have others put theirs?
Old 12-02-2009, 12:32 PM
Knight2's Avatar
Knight2
Knight2 is offline
Yo LoCo! lol
Check out this dude on Ebay! I may get a ket from him but he explains where to put his!
Maybe you can get some ideas!
Good luck
Read each section good to learn where he puts them'
Wonder if it's ilegal to put a strip right along the sides of the front floorboards! I'd like that...
Pete
http://cgi.ebay.com/ebaymotors/96-LE...Q5fAccessories
Old 12-02-2009, 03:07 PM
pled55's Avatar
pled55
pled55 is offline
generally you put one behind the horn.one behind airbox.four under fuel tank at each corner and the strips you would maybe put on the saddle bag rails away from moving parts
and hide your switch on the flat surface behind the engine on the frame.
and you should be good to go.be sure before you stick them on that the surface is clean and dry. i used alcohol to clean the area
Old 12-02-2009, 03:19 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
with that few pods you are going to want to put them all around the motor... to light up a motor we use 10 pods typically wiht 5 LED's per pod. To do the whole bike we use 15... on our strips we adjust with the amount of lighting... trick is to hand place and test each light. we make special brackets to get the most out of each light... it is all in the placement... the leds should only create an effect, NOT be seen... i hate it when people do rush jobs and you can see LED pods all over everything
here is a 10 pod engine kit
here is a 15 pod kit
and a chopper with our stip lights in hyper white on the polished motor and ultra white on the wheels
Old 12-02-2009, 03:38 PM
Coastiejosh's Avatar
Coastiejosh
Coastiejosh is offline
Put the lights where people can't see the source of light.
Old 12-02-2009, 05:37 PM
Ultra-Rick's Avatar
Ultra-Rick
Ultra-Rick is offline
Placement is critical to maximize light and keeping lights out of sight. When placing the lights, I temporally connect the lights to the battery and use masking tape to hold the lights in place until they are all where they work best.
Old 12-05-2012, 06:57 AM
DrunkenCynic's Avatar
DrunkenCynic
DrunkenCynic is offline
3rd Gear
Originally Posted by Knight2
Yo LoCo! lol
Good luck
Pete
I have a kit from Joe Florida, 168 LEDs love them and get a lot of comment, net of all my bike is very visible. Recommend you get it directly from his website, not eBay
DocKile
2014-2023 Touring Models
32
06-04-2015 10:05 AM
MIBPreacher
02-21-2012 04:46 PM
steelerdude1
12-04-2010 12:04 PM
RCNFVR
10-27-2008 01:50 PM
SteelCityScooter
05-30-2007 11:40 AM
Quick Reply: Where to mount accent lights
