Lizard lights install Questons
Old Oct 26, 2008 | 06:52 PM
RCNFVR's Avatar
RCNFVR
Default Lizard lights install Questons
I have lizard lights on my ultra under the tank would like to add more to light up front wheel and maybe some on bottom of saddle bags.Anyone done this and have advice on where to mount and how many to give off a good look front and rear to show off spoked wheels? Thanks for your help
Old Oct 26, 2008 | 07:26 PM
Chicago Spike's Avatar
Chicago Spike
Use some masking tape and a 9 volt battery. Put a light pod in a spot with the tape. The use the 9vt to see how the light pattern shines. This allows you to move the pod easily before permanent mounting tape is used.
Old Oct 26, 2008 | 07:46 PM
Bad Pig's Avatar
Bad Pig
good idea!
Old Oct 27, 2008 | 11:40 AM
RCNFVR's Avatar
RCNFVR
Anyone have suggestions where to mount lights to light up front wheel and where to run wires so they don't stick out big time? Thanks again
Old Oct 27, 2008 | 11:51 AM
LPFRAY's Avatar
LPFRAY
Tire side of brake caliper. Also try: http://www.boogey.com/home.htm
Lots of info on lighting up a bike there, also good product and people. Meet the owners in 04 at Bikes Blues and BBQ.
Old Oct 27, 2008 | 01:50 PM
Chicago Spike
Like I said, play around with them to see where they light up where YOU want them to. After that, then you find a way to route the wires. Be sure to leave some slack if you mount any lights to a suspension piece like the forks or swingarm areas. Mounting to the calipers you will need to add slack for travel both up and down travel.
nightrodjc
Electrical/Lighting/Alarm
Mar 13, 2014 08:24 AM
bigheadted
Mar 7, 2014 08:20 PM
Asclepeus
May 7, 2012 10:08 PM
zigster
Jun 10, 2007 08:22 AM
100thRK
Mar 18, 2006 04:42 PM
