Accessory switch ?
Old 12-24-2009, 09:09 AM
StreetKing's Avatar
StreetKing
StreetKing is offline
Can you use that plug to run a GPS?
Old 12-24-2009, 11:05 AM
quigley's Avatar
quigley
quigley is offline
Talking
Yes you can.
Old 12-24-2009, 11:09 AM
bagman1's Avatar
bagman1
bagman1 is offline
Originally Posted by wing_rdr
The rating for the accessory switch is 15 amp and there is a separate fuse in the main fuse box that controls the load in the switch circuit.
Thanks for the info, I just found that in the book. Does anyone know if a 15 amp circuit on the access switch will run heated gear safely?
Old 12-24-2009, 11:16 AM
BillinPA's Avatar
BillinPA
BillinPA is offline
I think it will. My heated gear Harness has a 15 amp in it. I haven't used it more than a couple times yet. So far so good. I wired mine into that connecter on my 09 RG.
Old 12-24-2009, 06:59 PM
vanman59's Avatar
vanman59
vanman59 is offline
Thumbs up ACC SWITCH and a relay
I use my ACC switch and plug for my heated gear. The only difference I did was I went to pull-a-part and got a relay and socket from a Nissan car and wired the relay so the ACC SW turns the relay on and off. I put a 10 amp fuse in between the battery and the relay contacts to run my heated gear. Works great. This keeps my heated gear on its own circuit and fuse. The relay draws next to no current.
Old 08-19-2014, 11:06 PM
CISSP's Avatar
CISSP
CISSP is offline
2nd Gear
Default Electrical troubleshooting 02 FLHT
I have no power on my accessory plug under the seat. I was trying to hook up a GPS. Here's what I did.
1. I located the plug under the seat and put a multimeter on the black lead and the orange lead.
2. Turned on the ignition switch.
3. Turned on the accessory rocker switch.
4. The green light on the rocker switch went on.
5. The multimeter showed approximately 12 volts while connected to black and orange. Good to go.
6. Tapping into the accessory orange wire, I connected my red GPS wire to it.
7. Tapping into the accessory black wire, I connected my black GPS wire to it.
8. Somewhere along the way I accidently crossed the black and orange accessory wires.
9. Turning on the ignition and the accessory rocker switch I now get no power and the green light on the accessory switch does not come on. I figured all I did was blow the fuse.
10. I checked the accessory fuse behind the left side cover and it is good.
I am stumped. Anyone have any ideas?
Thanks,
Bill
Old 08-19-2014, 11:14 PM
jdvorchak's Avatar
jdvorchak
jdvorchak is offline
Thanks,
Bill
I suggest you start your own thread about this problem. It's liable to get buried in this one.
Old 08-19-2014, 11:29 PM
CISSP's Avatar
CISSP
CISSP is offline
2nd Gear
Yes, thank you. I realized that myself right after I posted it, then I started a new thread. Thanks for looking out for me.
Old 08-20-2014, 05:04 AM
BoonDock_Saint's Avatar
BoonDock_Saint
BoonDock_Saint is offline
Originally Posted by Taylorized
I use mine to run the two blue lights on the rear.
I'd check Indiana statute re: blue lights on your bike. Some states reserve blue for the popo. It's a perfect excuse to pull ya over.
Are those metal overlays on the bags or a coating? looks very cool!
Old 08-20-2014, 05:49 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Weavr99FLHT is offline
Originally Posted by Sancho
If you hook something up to the accesorary connection under your seat, it won't work unless you turn on the acc switch next to the curise control.
not necessarily true. the acc plug under the seat is a 4 wire plug.
1: On with ignition
2: on with brake
3: on with acc switch
4: ground
Depending on the wiring of the plug that is plugged into it - the accessory will activate by either the brakes, ignition or dash switch. when you plug something in, you connect the ground and 1 of the other 3 wires. a HD accessory, with a plug already included, will be wired appropriately.
on my 99, i added extra brake lights, from HD, plugged directly into the acc plug and activated with brakes. On my 08, i added an accessory 12 v in the trunk, plugged into the acc plug and it is always on with ignition, regardless of the switch position. It depends.
Quick Reply: Accessory switch ?
