handlebars
Old Dec 22, 2009 | 05:09 PM
stglideblk's Avatar
stglideblk
Default handlebars
wanting to put WO575's on 06 streetglide and have used the search feature but still unsure on cables. Am i correct in assuming if i run the cables outside of the bars my stock cables will work and on the inside i need all of the cables? really don't want to jimmyrig. thanks
Old Dec 22, 2009 | 05:19 PM
DPete's Avatar
DPete
Bunch of threads on bars lately but if you want to call Wild1 here's their # 714-5365869 they have a tech you can ask about your year
Old Dec 25, 2009 | 06:16 PM
stglideblk's Avatar
stglideblk
Thanks DaPete, i did call and they told me +4 on all cables, seems like alot
Old Dec 25, 2009 | 06:24 PM
SMSgt B's Avatar
SMSgt B
Not sure about a 2006 but have those bars on my 2008 and used what I had on there. I did have to re-route the clutch cable but not a problem.
V/r
Old Dec 25, 2009 | 06:42 PM
'05Train's Avatar
'05Train
I'm getting ready to pull the trigger on these too. Has anyone done this on a Limited yet? Do you have to extend the TBW harness, and what's involved with the heated grip wiring?
Old Dec 25, 2009 | 07:57 PM
mtclassic's Avatar
mtclassic
I just put on Klockwerks ergo bars and needed nothing on my 04 EGC and I ran the wires inside. Noway would the stock cables worked with the 575's from what I have seen. I think 4" longer would be about right maybe get by with 3". the wires would not be the problem but the clutch cable and the throttle cables would be stretched too tight.
Old Dec 25, 2009 | 08:01 PM
lp's Avatar
lp
You can make the stock cables work but you don't want too. Get 3" over Clutch, Throttle, and brake line and do it right. The control wires will work wiring them through the bars....
lp
Scoobydann
Jun 6, 2015 05:44 PM
apetterez
Jan 21, 2015 04:35 PM
nicksiu82
Jun 21, 2010 10:33 PM
americanthunder
Jul 5, 2009 02:32 PM
blueduece
Jan 15, 2007 12:39 PM
