Mount hole dimensions for 09 tour pak?
Hope this helps.....
Just happen to have my new tour pak on my work bench with a detachable rack.
The front hole measures 1 3/16" (center) back from the front edge of the detach rack.
The rear hole measures 10 5/16" (center) back.
With the curve on the bottom of the tour pak, it would be hard to get an accurate measurement just off the tour pak.
thanks. suppose you coould get me the measurements of the holes off the box itself.i already got the the detatch bracket. just trying to figure out where to drill the holes in my new box
Hawkeye....
The front of the detach rack is flush with the flat (not the up-curve) of the bottom front of the tour pak.
You can see in my previous 1st pic, that is the bottom of the backrest pad above the rack. The rack is as far forward as it can go.
Line up your fronts.....center it.....you should be good to go.
Lining up the fronts would have your tour pak in the rearmost position. Providing more room for your passenger.
Last edited by twodollarbill; 12-25-2009 at 08:38 PM. Reason: added more info.....
