Tour Pak Latch Adjustable???
Jan 18, 2010 | 07:44 PM
MODERATOR
Can the TP latch on an '08 UC be adjusted to provide a bit more tension in the closed position?
The rivets are solid but when flipping down the little handle, one latch is a bit more loose then the other.
TIA!
Jan 18, 2010 | 08:02 PM
Your best bet might be new latches. They gradually wear over time, and they're not very expensive.
Jan 19, 2010 | 07:06 AM
Jan 19, 2010 | 12:36 PM
I cut a small sliver of velcro and stuck it on top of the lower latch receiver. It tightened it up and no rattles.
Jan 20, 2010 | 01:13 AM
Well you could thicken up the rubber gasket seal around the TP, but I reckon I would just replace the latches as a pair.
One of the last few remaining things that are reasonably priced by HD-- until they read this thread anyway.....
Jan 20, 2010 | 07:08 AM
the bottom half of the latch is kinda adjustable.... if you adjust um any, make sure to put some thread lock back on the screw
KSGLIDEGUY
2014-2024 Touring Models
Oct 15, 2014 10:34 PM
Intrepid175
Oct 19, 2012 07:20 PM
Dandy1
Dec 25, 2010 03:13 PM
trigger1911
Jul 11, 2009 09:39 AM
jahays32
Jun 7, 2008 10:44 PM
adjust ,
adjustable ,
adjusting ,
classic ,
harley ,
hd ,
latch ,
latches ,
pack ,
packs ,
pak ,
rattle ,
tour ,
tourpak ,
ultra
