Rivet holes oblonged on tour pak latches
Old Jul 11, 2009 | 07:24 AM
trigger1911's Avatar
trigger1911
Default Rivet holes oblonged on tour pak latches
My entire tour pak hinge/latch setup is loose so I bought the wonderful Harley latches and found out the holes in the tour pak lid are oblonged from being loose. Any ideas to fix. Screws wont work.
Old Jul 11, 2009 | 07:26 AM
quinton's Avatar
quinton
you might look into pop rivets and a washer.
Old Jul 11, 2009 | 07:29 AM
trigger1911
screws and pop rivets interfer with the closing of the lid. Thats why Harley uses those ridiculous little flat rivets. Thanks anyway
Old Jul 11, 2009 | 07:46 AM
smokindave's Avatar
smokindave
Re-fill all the holes with a good hard drying 2 part epoxy and then re-drill holes to fit new hinges.
Old Jul 11, 2009 | 08:44 AM
Harleypingman's Avatar
Harleypingman
Sorry to hear of your trouble. You might try aluminum or steel thin-wall tubing to create sleeves around the hinge hardware that fits into the sides of the lid and bottom.
Also, if the HD chrome hinge kit you bought has a PN ending with "-08," you might return them for the newer kit (introduced within the past couple of weeks with a "-08A" ending. The former were not intended for use with fiberglass tour paks.
Curious, how old is the tour pak?
Old Jul 11, 2009 | 09:00 AM
katobird's Avatar
katobird
LIke my tour pack luggage rack, when this happens to me i will be putting a aluminum plate on the inside to help distribute the stress..plus it will be installed with a rubber sealer to isolate vibration somewhat.
The luggage rack I used 1 1/2" round aluminum "type" washer under each bolt
this is the crap you learn while in Aviation.....
Old Jul 11, 2009 | 09:35 AM
will2002's Avatar
will2002
I vote for the "smokindave" fix! JMHO
Old Jul 11, 2009 | 09:39 AM
1flhtk4me's Avatar
1flhtk4me
Drill the holes larger and use larger rivets?
Intrepid175
Oct 19, 2012 07:20 PM
remike
Aug 20, 2011 11:29 PM
Dandy1
Dec 25, 2010 03:13 PM
Curlee
Oct 24, 2008 10:55 PM
jahays32
Jun 7, 2008 10:44 PM
