Update on the 25 degree injectors!
Just returned from a different dealer today with my 06 RKC. They had no problem swapping out the injectors, and they got me in real quick. I drove the bike home and it runs great. But I have a question for those who know these things. When the service guy said they were done with my bike I asked what kind of changes they had to make to the ECM. He said they only changed the injectors. I mentioned that the service bulletin said something about "update the ECM calibration". He said it wasn't necessary. So my question is, is he telling me the truth?
RE: Update on the 25 degree injectors!
they should download the stock map for 25 degree injectors, the one for the 8 degree injectors is different. probably doesnt change much, now you should get a pcIII or a sert and get it dynoed. if you get the sert, make sure you have the pipes and air cleaner you want, and dont plan on changing anything for awhile after cause it costs about $250 to get it dynoed. the sert changes your stock ecm so if you got a sert you wont need any download for the new injectors
When my dealer changed my bike to 25 degee injectors they also did a new download. I don't understand why they did not do yours. They should at lease explain to you why they felt it was not necessary. If your bike is now running good, maybe there is a method to their madness.
Maybe, and I'm guessing. That the new 25 deg injectors have a better spray pattern with minimal increase in fuel. Thus, you may not have a problem with the heat and being lean and the new download just keeps the bike in a lean state. Keep check of your mileage and plug condition.
ORIGINAL: websterdan
I have my 06 Roadglide in right now for the same thing, coughing and a stall or two, plus popping on decel. Getting the 25 degree inj. and am installing an PCIII on it as soon as I get it back. I know it has to be running lean, the thing goes into heat management way too easily, plus that popping has nearly gotten me killed twice due to the sudden loss of power when it happens. I'm positive once these changes are made, the bike will be running like a champ!
