PC-V Auto Tune problems - No Trims values...????
Select Power Commander Tools Configure Auto Tune.
Select the Auto Tune Enabled box to enable or disable Auto Tune.
Select the Enable Hardware Switch box. When selected, Auto Tune will not start until the switch on the handle bar is toggled.
just my $.02
Thanks for all the suggestions.
RMD - I do have the correct termination plug installed, I even removed it and checked it with a meter to insure it had continuity.
iClick - when the switch is off, it is in a "normally open" condition. When it is turned on, it is in a "normally closed" position and should allow the AT trims to actually take effect "live". I made sure I turned the ignition switch on & the run switch too, when checking for voltage on the accy wires - thanks though for helping me remember all the little things.
valleyracinginc - I think you may be on to something here. I am aware that the "dual" map switch can't be enabled at the same time as Autotune. I may have described it wrong. I have enabled Autotune & the Hardware switch. The way Keith from FM described that the hardware switch would work - he told me that when off (open) I would be running the base map. When on (closed) I would be running the live suggested AT trim values. But maybe this is not correct, I might have to turn the switch on (closed) when I have the hardware switch enabled in order for Autotune to work. Currently I have disconnected the switch, physically. I have not had a chance to connect with my laptop yet, but will tomorrow. I will then disable the hardware switch and then see if Autotune suggests any trim values after tomorrows ride.
Again, thanks to everyone for all the assistance.
I couldn't wait till tomorrow, so I just went out to the parking lot & hooked up my laptop. After riding 375 miles today I still had no trim values, this is after I pysically disconnected the "MAP" switch from last night - but I did not disable the "Hardware switch" in the software.
So what I just did right now, was connected to the PC-V with my laptop. Pressed "Get Map" - no trims values from autotune. I disabled the hardware switch. Then disabled Autotune, then re-enabled it. Hopefully, when I finish riding 300+ miles tomorrow, I should have some Autotune suggested trim values.
Thanks to All!
Keith is correct and that's the way it works on my bike. Open circuit (switch off) is base map only, closed circuit (switch on)
is closed-loop mode. I would assume that it will not adjust trims while the switch is off and running only the base map.
Thanks much!
Try shorting the PCV map-switch holes with a short wire and see if your trims change. That's the same thing as having a closed switch.
that's carrying any DC power.
To repeat, remove the P&A fuse in the fuse panel. When the ACC switch is in the "on" position (i.e. switched down toward the LED bulb on the switch) you should be running in AT. Switched up you will be running the base map only, and trims will probably not be updated.
Thanks much!
