Autotune problem no trims
Old Mar 19, 2011 | 07:25 PM
7Sixpack7's Avatar
7Sixpack7
Default Autotune problem no trims
I installed the autotune put about 20 miles on the bike came back to check trim levels and no trim levels. The autotune is enabled in the pcv. I have the autotune plugged into the diagnostic plug (identified per the fsm) have all the colored wires in their respective holes and screwed down. They are hooked up from #1 = front cylinder and #2 = rear cylinder. Can bus cable connected from PVC to autotune and termination plug is installed. Up graded the pcv software to 1.0.4.0 and the firmware to the latest 1.5.5.5. I have the base map from fuel moto installed. The bike runs fine just the autotune isn't working. If I start the bike the computer will read the rpm's, fuel adjustment and the duty %. Since I updated the software the engine temp does not read anymore. One more question, my autotune is only 1 box and not two like the instructions call out. Must be the latest version? Also the green lit is lit on the pcv and the red light on the AT blinked 3 times twice before it stayed lit constantly. Any suggestions?
Thanks Phil
Old Mar 19, 2011 | 08:09 PM
a34655's Avatar
a34655
After I installed my autotune it didnt show any trims either. It also didnt show any ECM data, including temp. I called Fuel Moto they walked me through some tests and it was determined my PCV was defective. They replaced my PCV even though it was out of the warranty time. After that everything was working.
Old Mar 20, 2011 | 05:13 PM
7Sixpack7's Avatar
7Sixpack7
It was suggested in the touring forum to update the firmware again. I uninstalled PCV software and reinstalled it then downloaded the latest firmware and installed it also. just got back from a ride and still no trims.............until I clicked on "get map" and the new trims showed up. Clicked accept all trims and trims zeroed again. I have to say the instructions are vague as h3ll. So all is good. Thanks to the members that had input!
7Sixpack7
Jun 3, 2012 01:11 PM
jlasoftail
Apr 10, 2012 06:45 PM
Big09StreetGlide
Jul 4, 2011 08:07 AM
Cheiron
Aug 20, 2010 11:05 AM
tekeum
Jun 14, 2010 04:42 PM
