Ive just noticed recently that when the bikes in first gear, with the clutch lever pulled in and i try to roll it. The bike will not move. Is this some thing that a simply clutch adjustment will fix? Also wheres the best place you guys have found to buy a maintinance manual.
'06 service manual #99483-06 and Touring Models parts catalog #99456-06 are must haves. I have an '06 EGC and it is difficult to roll as you describe when the motor is not running. When running there is no problem maneuvering. Might just need a little tweaking.
Hope you get some more replys. I've had the same problem with mine since new and got worse after clutch adjustment. Thought maybe it was just the natue of the beast.
If it's just harder to roll than when in neutral, that's normal. If it won't roll at all, you clutch needs adjusting. Does it try to creep forward on you with the clutch pulled in and the motor running?
If your trying to do this while the bike / fluid is cold and the bike is not running, it is normal. The clutch plates are sticking together because of the oil in there.
No creep, But every things fine when I'm riding around. just not when its stopped
I tend to go through car service manuals pretty fast (reading when hands are dirty). So I tend to buy Chilton's or Haynes manuals cause there cheaper. Do they make manuals for HD. The dealership had one that was $60.
