Help 06 Electra glide
Old Mar 22, 2010 | 09:58 PM
soos's Avatar
soos
Originally Posted by Bigredone
You can get the CD version on ebay for less than $10. The book is more expensive.
LOL, you just gave the kiss of death to this thread.
Old Mar 22, 2010 | 10:28 PM
Bigcim's Avatar
Bigcim
Originally Posted by soos
'06 service manual #99483-06 and Touring Models parts catalog #99456-06 are must haves. I have an '06 EGC and it is difficult to roll as you describe when the motor is not running. When running there is no problem maneuvering. Might just need a little tweaking.
Whats the difference between 99483-06sp and 99483-06
Old Mar 22, 2010 | 10:32 PM
soos's Avatar
soos
The SP is for the FLT police models.
Old Mar 22, 2010 | 10:40 PM
juscoop's Avatar
juscoop
Does the bike push forward when running in gear if so the the cluch needs to be adjusted . When my bikes are cold and in gear with the clutch pulled in are hard to push also but that is normal. After the bikes is are warmed up they can be moved easy.
Old Mar 22, 2010 | 10:59 PM
Antnee 2004 FLHT's Avatar
Antnee 2004 FLHT
My bike is the same. I kind of like it that when its cold and in 1st gear that it will not roll. makes me less nervous about someone messing with the bike and dropping it. You should be able to quickly shift into neutral without starting the bike and it will be easy to move.
Old Mar 23, 2010 | 10:20 PM
Bigcim's Avatar
Bigcim
No the bike does not push forward when running in gear. If I start the bike in gear with the clutch lever pulled in the bike will jump a little.
Old Mar 23, 2010 | 10:58 PM
Turbo Turtle's Avatar
Turbo Turtle
Mine does this also, but not so much when the oil is hot. from reading, as long as it doesn't pull you forward with the clutch in you should be alright.
MercStitch
Oct 16, 2016 09:34 AM
bigram23
Jul 13, 2016 09:42 AM
Tree Top Flyer
Sep 21, 2012 03:41 PM
toywheeler
Jun 30, 2009 08:08 AM
beendad
Jul 24, 2007 04:20 PM
