Clutch adjustment
Old Sep 21, 2012 | 02:47 PM
Tree Top Flyer's Avatar
Tree Top Flyer
Stage I
Default Clutch adjustment
I need some information on how to adjust the clutch on my 2012 Electra Glide Ultra. Engine won't start in gear, and bike "cheats"ahead when stopped with clutch in. Thanks, TTF
Old Sep 21, 2012 | 02:58 PM
nvsteve's Avatar
nvsteve
Bike should start in gear with clutch pulled in. It will "cheat" when cold but should be ok when warmed up. Do you have a lot of slop at the lever. If so, adjust the cable. If not, you will need to pull the derby cover and do a full adjustment. Hopefully you have a service manual.
Old Sep 21, 2012 | 03:06 PM
56tbird's Avatar
56tbird
+1 on the service manual... best add-on you will buy.
If you have to adjust it at the primary, adjust it to your liking.... I personally like the clutch to engage a little earlier that most... useful when using the friction zone in slow/tight spaces. I just had my 10K service done and the dealer adjusted it the other way..where it engages late. I'll be fixing that this weekend.
Old Sep 21, 2012 | 03:25 PM
vistavette's Avatar
vistavette
do a search on youtube for Harley clutch adjustment; you'll find a good video that will walk you through it. Very easy....and order the service manual; it comes in handy
Old Sep 21, 2012 | 03:41 PM
motorlessons's Avatar
motorlessons
First, the bike must be cool when you do the clutch adjustment.
1) Slide the rubber boot off the adjustment nut assembly, in the clutch cable. Use a ˝” and 9/16” wrench to loosen the jam nut back, then induce the maximum amount of slack.
2) Remove the clutch inspection cover, loosening the screws in a “star” pattern. Use a sharpee pen, and mark the inside of the cover, to indicate which hole is the one that was on top. Always install the cover so that that hole is the top.
5) Loosen the 11/16” nut in the center of the clutch housing.
6) Using an allen wrench, loosen (counter-clockwise) the clutch adjuster screw, which is inside the 11/16” nut you just loosened.
7) This is the critical step. Gripping the shaft of your allen wrench with just your thumb and index finger turn it back (Clockwise) just until the point that you feel the least resistance. NO MORE!
8) From that point, loosen it back (Counter-clockwise) ˝ turn to one full turn. If you use the clutch to control the motor at low speeds, you should use ž turn. ˝ turn is for “normal riders”, who use the clutch like an on/off switch. 1 turn is appropriate for a police bike in city traffic service.
9) Holding the allen wrench, so the screw stays in position, tighten the clutch adjustment nut. There is a torque value, but unless you have a crow’s foot, you can only tighten it so that it’s snug. If you are using an open-end wrench, take care not to let it slip off the nut, since you will be at an angle to the nut. If you do have a crow’s foot, it calls for 8 to 10 ft.lbs.
10) Replace the cover, making sure the gasket is good (actually on your '09, it's an "O" ring, they usually last the life of the motor). Tighten the screws in a star pattern, to 50-70 inch pounds of torque.
11) Tighten the cable at the jam nut assembly. Once it is roughly tightened, pull the clutch lever three times to seat the ball and ramp in the mechanism. Then tighten to the point that there is about 1/16” of free play at the lever. If you pull the cable housing out from the lever, the edge of a nickel should just fit between the shoulder of the cable, and the bracket.
Harris
Denver, CO
www.youtube.com/conedown
Railway-man
Apr 18, 2016 06:25 PM
bran48
Mar 16, 2014 10:40 PM
grantb
Ironhead
Mar 3, 2011 10:03 PM
straitshot151
Nov 28, 2008 09:34 PM
HDHoosier
Feb 5, 2008 06:46 PM
