Fuel Tank removal - Oh What a MESS!!!!
So after reading the advice of others, and getting some clarifications from a few, I removed my fuel tank last night. I had made up some hose plugs as one rider advised but when I started the removal I had left them in the house. Besides, I just purchased a "good" siphone pump - who could asked for anything more - right?
Well I now feel as I have "passed" my initiation into this wonderful brotherhood. After siphoning out what I thought was all the gas in the tank, I started doing the disconnects. Everything was going fine UNTIL it came to to taking off the crossover fuel line. That's when I found out that the tank was nearly as empty as I had thought. Boy, does a moderate amount of fuel make a HIGH mess. But at least the tank is off now and I can start doing my "reworks". I'm looking foward to reinstalling the crossover line with the recommended valve so as to not have to go through this ordeal again. Mind you, if I had slowed down just a little bit, and had the hose plugs "at the ready" - none of this would have happened.
For any others that are considering to remove their fuel tanks - READ and FOLLOW the advice given through the "posts". You'll be glad you did.
Thanks to all that helped.
I am laughing hard but not at you with you. Becaus i suddeny don't feel so alone ;-)
Took apart my 2004 fxsti tank last week ( for the second time) and cussed up a storm in the garage. Tried siphoning as much as i could but still manageg to get gasoline evrywhere. Add to that kids toys lying around in the garage that made me trip with full jerry can of gas..+ The wife asking if i couild be alittle tiser because she could smell gasoline on house..;Arghhh I never thought i would but i sooo miss my carb sporty: no fuel injection. no unreliable fuel gauge and no close calls with imolation while trying to remove my gas tank :-)
I got this Colder (I think the same that Herko recommends) fitting for a crossover and I can't seem to get any combination of hose length that'll make it work. Since this is for a Softail (sorry if I crossed the line ) do you think that the width between the crossover tubes is less then the Touring models?
Or are you all using a more flexible line than the factory one? I think if the line has bit more flex in it then you could get enough room to pull the coupling apart. It just seemed like when I was fitting it on the bench that I couldn't get the hose to bend or kink enough to get a straight shot to connect it without potentially screwing up the o-rings.
I effed up the o-ring in the fuel line disconnect a few years ago so I'm a bit cautious now.
-DO
-DO
Drain Gas From Crossover Quick Connect
Draining a Gas Tank is simple. If you are putting a Quick Connector or Quick Release in the crossover why not use a Safety Drain?
Safety Drain gives you a plastic piece for the connector that attaches to a drain hose. All you have to do is disconnect the quick Release and then plug in the Safety Drain and you are draining gas fast, easy and with no sucking mess!
They are on E Bay
They are on E Bay
