Advice for 100+HP
Advice for 100+HP
I ride a '09 Street Glide with just the stage I kit, I would eventually like to be around 100HP. I dont know if the 110 kit is worth the money or if the 103 kit will have the horsepower. It seems the mechanics/riders I have talked to all have a different answer. Any suggestions or help in the matter?
Received 71,182 Likes
1 hp/ci is very do able & a lot less expensive than a full teardown to bore the cases. I'd personally go the 106-107 route, either of those combined with a good P&P on the heads & a good cam selection should easily give you 100-115hp. Get with a good builder & explain what you're looking for & what your riding style is, are you looking for tons of tq down low or do you want hp at the top end.
Just going withthe 103 big bore without bumping compression and cams will not get you to the century mark. A well prepped 103 or 107 will with the heads, cams and comp increase as well as a free flowing intake and exhaust will get you there and beyond. Check out www.protwin.com as well as some of the sponsors of this forum for more info.
