autotune question.
I searched last night and today I'm out for a ride. I installed the autotune but I can't tell if its sampling. I enabled it in the pcv but did not install a toggle switch. Is the default set to autotune or do I need to put in a jumper?
As long as it's enabled you should be good to go. You can always retreive your MAP from the bike and compare it to your starting MAP and see if there has been any changes to it.
I figured out since it doesnt come with a switch you need to put a jumper in pins 1/2 to use autotune. I did run it and did a few blasts up the highway. I see info in the trim table now/.
NAUIdvr1
Fuel Moto / Jackpot Mufflers
Apr 26, 2010 03:07 PM
DrPlastic
Mar 16, 2010 06:58 PM
