SE Compensator
You should weigh the cost/performance differences, for people that are going to do a cam change anyway this is a way to kill 2 birds with one stone.
I used a HeadQuarters cam.
A change in timing will also mask the problem..for a little while anyways.
Just remove the stock comp and you'll see the problem...the ramps will probably be polished and maybe a lobe or two even damaged.
I changed the compensator on my 03 Dyna from 25T to 21T, which is a 19% increase in torque. That is VERY noticeable!
If anything a cam upgrade will increase the problem, it is a known weak point on bikes that are ridden aggressively, and often seen on upgraded motors. In fact I am in need of replacing mine now and it was fine prior to my cam swap, maybe I just used the wrong cam. Of course I have been known to ride it like I stole it, before and after the big bore upgrade, but with big bore I have much more HP/torque to abuse the compensator.
Hobe
I thought most true performance cams lower cranking compression, that alone should stop the bang, and as I said before I have a friend with same bike same performance upgrades and a different tuner (I have an SERT and he has a Powercomander) and it stopped the bang on both bikes.
Just for the record I do tend to treat my bike like a rented donkey quite often.
As someone else has already mentioned this issue isn't just a start up issue, in fact it is likely no problem at start up. The problem is under acceleration or hard decel, you will get a clunk in either case, and it can get pretty severe. I can speak to this as I can reproduce it any time with a blip of the throttle, or a quick downshift.
As far as non stock cams lowering compression, well most of the time this may be true, but it is the duration that determines this. Some cams such as the SE 255 can buck this theory, so it depends on what cam you are talking about.
But from your post it sounds like what you are talking about is starter kickback, and this is common on HD bikes, particularly if you start a heat soaked motor. You are correct that if you replace your cams with something with more duration you will effectively reduce dynamic compression. If this is the case you will likely reduce start kickback, but you are also likely to reduce the motor output potential from the cam swap. Typically when swapping to cams with more duration you want to increase static compression to compensate, and to maximize the performance potential from your new cams.
Now once you start getting to this point you will find that you are really hammering that stock compensator, as I can verify. Unfortunately once you reach that point there isn't much else you can do, the SE comp is about the only option available. Once you head down the road of performance upgrades it seems to never stop, so now i need a new SE comp, with my performance cams installed.
Hobe
Just to add, was up in Idaho in May, you guys have some beautiful riding up there. Spent 12 days riding and covered about 5400 miles, and a fair number of them were in Idaho.
Ride Safe
Hobe
