clutch
Old Jul 12, 2010 | 03:34 PM
paguy's Avatar
paguy
Default clutch
Been having problem with my 07 RKC clutch. Thinking possible warped plate. Anyway, go to Harley Davidson site and can only find the screaming eagle disc and plate kit. No problem, price isn't that bad.
Then I call dealer parts dept. and am told screaming eagle won't fit my hub. Will need to buy hub and all.
Does anyone know if HD sell a simple relacement set of plates and discs for my RK. Thanks.
Old Jul 12, 2010 | 03:38 PM
07RoadHawg's Avatar
07RoadHawg
Yes, the SE plates will fit your hub. I have them in mine, specifically PN 37969-03A. Or you can check out Phat Performance (site sponsor) and get a set from BDL, Barnett, and others.
Once you do that, find a new dealer that knows what they are talking about.
Old Jul 12, 2010 | 03:43 PM
tombeving's Avatar
tombeving
In the 05 touring parts manual the number for the clutch plate is #37913-98 and the number for the friction plate kit is #37932-98. If the clutch plate number is not a kit, you will need 8 of them. I'm pretty sure these will work for an 07, but check with the dealer.
Old Jul 12, 2010 | 04:56 PM
trackadaptor's Avatar
trackadaptor
Cool Bad Dealer
Go find a new dealer:
http://www.harley-davidson.com/dwp/g...bmLocale=en_US
Screamin' EagleŽ Performance Clutch Kit
Kit increases capacity of the '98-later clutch design by over 28% to 125 lb.-ft. of torque at the crank. Includes new long life friction discs, steel plates, and 10% higher-pressure diaphragm spring. Clutch Spring P/N 37951-98 is also sold separately to assist in increasing capacity of stock clutch.
Fits '99-later Twin Cam-equipped models and '98-later EvolutionŽ 1340-equipped models.
37969-03A
Our Price US $169.95
Buy this product online from our dealership at
harley-davidson.com
Required Item(s)
Heavy-Duty Clutch Spring for Stock Clutch
Fits '98-later Evolution 1340-equipped models and '99-later Twin Cam-equipped models
37951-98
Our Price US $29.95
harley-davidson.com
Old Jul 12, 2010 | 06:39 PM
2nd Mike's Avatar
2nd Mike
You should check out the Barnett "extra" set.
It eliminates the double steel drive plate(that my rivets popped out of).
It comes with 9 friction plates and 8 steel plates to keep the original thickness.
And yes,it will fit on your hub
Hog Yild
Jul 6, 2019 08:58 AM
trackadaptor
Nov 10, 2012 04:04 PM
hangemhigh2011
Apr 18, 2012 10:20 AM
2001 Softail Deuce
Apr 28, 2009 08:12 PM
jat3
Nov 29, 2007 08:55 PM
