won't start
Old Jul 18, 2010 | 07:36 PM
nikon's Avatar
nikon
Default won't start
i push the start button on my 03' roadking, and just get a click. i had the battery checked and it's 12.7 volts. any ideas ?????? thanks
Old Jul 18, 2010 | 07:48 PM
dawg's Avatar
dawg
Check all connections to make sure they are good and tight. Check the relay. Check fuses.
Old Jul 18, 2010 | 08:07 PM
shortride's Avatar
shortride
You should consider checking the terminals for tightness and clean the terminals if you haven't already.
12.7 voltage check does not necessarily indicate a good battery. When cranking, the amperage of a battery is what counts the most. A battery can have a weak cell and still register 12.7 volts. You need to have the battery load tested at your nearest reputable auto parts store.
Old Jul 19, 2010 | 01:12 AM
Enforcer419's Avatar
Enforcer419
I had the same thing happen with my '05 EGC. Dealership replaced silenoid and starter. No problems since
Old Jul 19, 2010 | 06:00 AM
kyote's Avatar
kyote
when checking your connections..remember to check the ground connections on the frame too..
Iarecobra
Jun 12, 2014 06:21 AM
pieisgood
Jun 5, 2014 07:09 PM
cowpoke
Engine Mechanical Topics
May 14, 2014 08:19 AM
mmartir_25
Aug 14, 2008 09:19 AM
starbucksound
May 24, 2007 11:48 PM
