I NEED HELP!
Old May 24, 2007 | 10:06 PM
starbucksound's Avatar
starbucksound
Stage I
Default I NEED HELP!
hit start button, clicking noise, checked battery, good voltage, checked connections, all tight. trouble shot as per manual i.e. circuit breaker, relay, etc. all came up fine. tore starter off bike, solenoid checked out good. continuity check good. where do I go from here?
Old May 24, 2007 | 10:32 PM
128auto's Avatar
128auto
Default RE: I NEED HELP!
Sounds like a weak battery to me. How did you check the battery? 12V doesn't mean the battery has enough power to crank. Did you check ground cable? Just a thought.
Old May 24, 2007 | 10:34 PM
user 37474839's Avatar
user 37474839
I second that..sounds like a Battery issue. How old is the battery?
Old May 24, 2007 | 10:37 PM
Wolhar's Avatar
Wolhar
Best check the ground connection at the Frame.
Old May 24, 2007 | 11:16 PM
UNCCHarley's Avatar
UNCCHarley
Without a doubt it is the battery. Before I sold my Honda it did the same thing. Do the lights dim when you hit the starter?
Old May 24, 2007 | 11:48 PM
bmkshort's Avatar
bmkshort
Sounds like a battery problem to me too. It might read 12V with no load, but see how much it drops while trying to start.
WVICEMAN
EVO
17
Nov 9, 2014 12:44 AM
Bowhunter61
Jun 15, 2012 04:11 PM
nikon
Jul 19, 2010 06:00 AM
mmartir_25
Aug 14, 2008 09:19 AM
hdpearson13
Ironhead
Dec 3, 2007 07:16 PM
